1971 DT1 clutch push rod
- Andrew60
1971 DT1 clutch push rod was created by Andrew60
Hi please could somone help me with clutch pushrod /2 length as I’m having to make one (silver steel) thank you
17 Feb 2022 01:08
Replied by RT325 on topic 1971 DT1 clutch push rod
Sorry--no help from me--but--I need one too. Think what i'll do is cut it too long then sit the actuator cover up to it with adjuster backed out a bit then measure the cover gap to the case best as i can. Bit of a juggle as cover will want to rock not sit perfect to measure. My motor is dodgy so original perfect Yamaha length probably doesn't apply anymore. Are they "1/4 for silver steel?. 50+ years since i've done one [in my BSA 500 1954] so just heat red the quench in oil? if my long term memory is intact lol. Thanks.
17 Feb 2022 13:53
- Andrew60
Replied by Andrew60 on topic Re:1971 DT1 clutch push rod
Thanks I’ve actually made one & done the exact same as you mentioned. But the clutch is not good so I’m waiting for replacement parts!
17 Feb 2022 14:38
- msavitt
Replied by msavitt on topic Re:1971 DT1 clutch push rod
mine is assembled so sorry I cannot provide length
I wonder is the yamaha rod is hardened to take point load from ball without galling?
17 Feb 2022 15:53
Replied by RT325 on topic Re:1971 DT1 clutch push rod
Awaiting clutch internal parts? other than pushrod. What's it doing--or not doing. Just me being nosy sorry.
17 Feb 2022 18:46
- Andrew60
The bikes been stood for ever & the clutch wear plates have nothing whatsoever on them! So new one ordered .
Sent from my iPhone using Tapatalk
17 Feb 2022 23:33
