Joined case halves... trans problem??
Replied by MarkT on topic Joined case halves... trans problem??
Apologies... just realized you were talking about centering shift linkage.
Manuals are in Tech Library here... just not sure if TY would be same as DT. (TY engine was a bit of an odd duck in some respects and I don't have a manual)
05 Oct 2022 09:17
#11
- PDXtyist
- Content Contributor
Replied by PDXtyist on topic Joined case halves... trans problem??
Thank you MarkT. I see how to adjust the Shift Linkage left and right about the Dowel Pins. I just don’t see how mine is hooking well enough the pins to actually rotate the drum in either direction. Seems it’s not reaching up enough. That’s why I wonder if it’s worn out.
- PDXtyist
Red background is the new one I saw on line.
05 Oct 2022 10:14
#13
I've never seen one wear out. But could be.
I have seen a lot of people struggle with "bench shifting". Get someone to spin the clutch input shaft continuously while you try to shift. Also make sure you have all the "detents" in place. (spring and plunger that engages cam on shift drum for sure)
They just don't shift well on the bench in my experience.
05 Oct 2022 11:34
#14
- PDXtyist
Thank you MarkT. Ok, excellent advice. I have my head around the gearbox. Now turning my attention to the shifting mechanisms.
05 Oct 2022 15:38
#15
Replied by RT325 on topic Joined case halves... trans problem??
#9 the TY. If you're trying to go through the gears without the plunger & spring it'll be up the creek. Plunger keeps it fully in gear n& then the claw arm will hook the next pin. Plunger & spring would make it hard to change gear on the bench unless held still & gear lever to operate the drum. If i'm on the right page, but hope ya sorted.
05 Oct 2022 17:18
#16
