Clutch side cover - DT400 twin shock
- Jammyyammy
Clutch side cover - DT400 twin shock was created by Jammyyammy
Hi - I’ve come to put the clutch side cover back on my DT400 twin shock.
I’ve got the correct gasket.
Should I also use some hylomar blue (non setting gasket + jointing compound) on this or can it go together dry???
Thanks….
Thanks….
27 Nov 2021 09:16
- Tinkicker
Replied by Tinkicker on topic Clutch side cover - DT400 twin shock
Dry.
27 Nov 2021 10:11
- Jammyyammy
Replied by Jammyyammy on topic Clutch side cover - DT400 twin shock
Thanks….
27 Nov 2021 10:25
- Pete-RT1
Replied by Pete-RT1 on topic Clutch side cover - DT400 twin shock
I smear a bit of oil on mine so that if I need to remove the cover again it comes off with the gasket intact.
I think I picked that tip up from RT325
Yamaha CT3 (in bits)
Replied by RT325 on topic Clutch side cover - DT400 twin shock
Wrote this but didn't push submit apparently.
Just grease it. Easier to get off next time. If there's case damage then that's a different story.
The following user(s) Liked this Post: Pete-RT1, Jammyyammy
27 Nov 2021 15:01
