Yamaha YG1 and L5T
- Rick C.
Replied by Rick C. on topic Yamaha YG1 and L5T
My father is out of the ICU. and doing better !! ( Thanks Mark, YEP..the power of prayer ! )
Time to hit it with a GREAT Exuberance !!!!
Back to the Air Cleaner build.
Screen is formed and held on by safety wire.
Makes it so you can just take the foam off to clean . I like that !
with that outta the way, time for mach-up the foam material..
17 Dec 2021 16:07
#61
- Rick C.
Not diggin on the gap'osis where the foam should fit snug.
I may just have to get me some Pilobond adhesive and make it a sock
.That would seal up the problem.
( UNI FILTER foam says to use either Silicone or Pilobond adhesives on their foam material . )
17 Dec 2021 16:17
#62
- Rick C.
Time to address the oil pump issue.
looks like the seals inside are bad. Leaks perfectly around the wheel and shaft.
Won't prime or even get a dribble out of the bleeder.
FUN FUN !!!
FUN FUN !!!
Replied by MarkT on topic Yamaha YG1 and L5T
Great news all around. Thanks for the update Rick!
P.S. If feed hose to pump is removed, does oil flow out of it? I've seen a blockage in the feed hose or tank fitting cause the symptoms you described. I think Yamaha had a screen in the tank outlet on those models and I've seen them gum up with muck and Panda fur.
The following user(s) Liked this Post: Rick C., t-bone, Ht1kid
17 Dec 2021 17:19
#64
- Rick C.
That's where I will be going next then.
Once again, Thank you Brother !!
17 Dec 2021 17:57
#65
- asco
Replied by asco on topic Yamaha YG1 and L5T
Rick, I hope that you father is doing much better..
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
19 Dec 2021 07:45
#66
- asco
We’re now on page 7. How is your father doing Rick? Hoping you have a fantastic 2022. Please update if you can…
yama-asco
yama-asco
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
08 Jan 2022 21:22
#67
- Rick C.
Thanks Curtis for bringing me back in on this.
My 90 year old Dad is still touch and go , after his massive coronary heart attack. He is out of the ICU and doing a little better but not out of the woods yet . Thanks.
Now back to the bike ...after going through just about everything in the book ( A book I never found !! )
she runs. And runs good too. Kept it at little under $350 in parts or so.
Some people may hear that, there might be a video or two out roaming around.
Hard to say.... I just rode.
- Rick C.
Pictures ??
I can do that.
Video.. naaaa.
OOOOHhh outside !!!
Don't you like the KDI , DT/RT seat foam for kicking it to life? works in a pinch too.
Nice picture Scott... a Hodaka Tee I am wearing !?!
I coulda wore something more nice !
I can do that.
Video.. naaaa.
OOOOHhh outside !!!
The following user(s) Liked this Post: t-bone, JGersh, Pete-RT1, Sneezles61, adguy2112
