Please help me stop blowing headlights!
Replied by RT325 on topic Please help me stop blowing headlights!
found a CDI box pic in which you can see the orange, black, & black white in one plug. But here's a regulator like IT enduro bikes run. Just google & there's heaps of similar ones.found a CDI box pic in which you can see the orange, black, & black white in one plug. But here's a regulator like IT enduro bikes run. Just google & there's heaps of similar ones.
06 Oct 2021 16:58 #11
  • ckjacks
  • ckjacks's Avatar Topic Author
Replied by ckjacks on topic Please help me stop blowing headlights!
Thanks RT! This is helpful. So the headlights run off AC?
Last edit: 07 Oct 2021 05:40 by ckjacks. Reason: typo.
06 Oct 2021 17:13 #12
  • ckjacks
Would the Trail Tech 7003-AC01 work? I've heard TT mentioned several times on here. If it will, how is it installed? Thanks for everyone's help!!
06 Oct 2021 17:18 #13
Replied by Hammer on topic Please help me stop blowing headlights!
Ckjacks,
YES, it does.  It can ALSO (magneto doesn't care about voltage) run 12V H4 Halogen auto bulbs when you add the voltage regulator.  I've been using them on my RT-3 since 2013, and haven't blown a bulb since then.  If you do a search on the name Hammer on this subject, you'll find my solution and photos of my installation using the stock voltage rectifier mount bolt  Mine's adjustable also..
Hammer
Last edit: 06 Oct 2021 17:24 by Hammer.
06 Oct 2021 17:21 #14
Replied by msavitt on topic Please help me stop blowing headlights!
1/2 the cost of a bulb and has a cool red light you will never see
I blew one along with the speedo and tach lights, $50 poof!
Last edit: 06 Oct 2021 20:04 by msavitt.
06 Oct 2021 20:01 #15
Replied by MarkT on topic Please help me stop blowing headlights!
Yes your headlight is AC.  It's a great system from an era when semiconductors were rare and expensive.  Balances load against output to regulate voltage.  I've written several lengthy posts on how it works, not feeling well enough to repeat it again but sure you can find with a search if you haven't already.
Rt325 is correct about not hooking up regulator to blue to tail on (most) US models.  Just follow the service bulletin.
06 Oct 2021 20:47 #16
MarkT, you look after yourself ya hear. I'm relying on you to sort me out at times. Second Covid jab did me in for a couple of days.
06 Oct 2021 21:37 #17
Replied by apex on topic Please help me stop blowing headlights!
I didn't see this mentioned after you asked, but, the rectifier is a completely different part that does nothing to "regulate" the voltage. Basically the rectifier eliminates the "spikes" from the battery's charging circuit's alternating current (AC) voltage. The battery needs direct current to charge, so the rectifier does that by chopping the AC's voltage spikes.
Allrighty Then
06 Oct 2021 22:30 #18
  • ckjacks
Hammer, this is great. So what does the yellow go to and what does the brown go to? Thanks!!!
07 Oct 2021 05:35 #19
  • ckjacks
Thanks, Mark. I did not know the headlight ran on AC. So, the regulator should be spliced into the blue wire in the headlight bucket?
Hope you feel better!!!
07 Oct 2021 05:38 #20
