Gasket question dt3
- principal282
Gasket question dt3 was created by principal282
The bottom gasket between cylinder and the case...why are there two gasket sizes? I tried to buy one on ebay using the right part number and it's about 10mm too wide. I learn there are two types and I am getting the other one on the way (thanks to the best parts guy I know Buzzard.)
more importantly, do you use like a blue permatex or yamabond on said gasket? Thanks in advance this green machine could come together sunday or Monday with a little luck
29 Sep 2021 20:04
Replied by MarkT on topic Gasket question dt3
Short answer: Shared parts lists for similar models that got screwed up when they went digital. You have to be careful and pay attention to part prefix (model code) and then it's still tricky sometimes. Been discussed here at least 100 times so if you search you'll find a lot of info.
29 Sep 2021 21:50
Replied by RT325 on topic Gasket question dt3
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=194363937420&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Partzilla lists are a bit of a cockup for DT2 & DT3. DT1 list gets it right--same base & head gaskets for yours.
www.partzilla.com/catalog/yamaha/motorcycle/1971/dt1e/crankcase
30 Sep 2021 00:51
- principal282
Replied by principal282 on topic Gasket question dt3
I have to get better at the search function! Thanks for the help
30 Sep 2021 04:16
