Dry v wet cell
- principal282
Dry v wet cell was created by principal282
Coming to the conclusion the dry cell battery is not a good fit for a 73 enduro...if I read right, charging system can't keep up?
lots of poor performance issues and a battery that dies quickly.. could be related?
another thread in 72-73 details my struggles with this.. I did order a wet cell battery yuasa from a reputable supplier. Need to find the electrolyte next
30 Aug 2021 05:05
- 1971DT250
Replied by 1971DT250 on topic Dry v wet cell
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=174636935402&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by MarkT on topic Dry v wet cell
Auto parts stores like O'Reillys and NAPA usually sell the battery acid for a couple bucks.
The following user(s) Liked this Post: principal282
30 Aug 2021 05:57
- darinm
Replied by darinm on topic Dry v wet cell
I've been really happy with that motobatt AGM battery too. Just beware if ordering from Amazon there is a significant chance they'll send the wrong size, happened 2/3 times to me.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
30 Aug 2021 09:44
- principal282
Replied by principal282 on topic Dry v wet cell
I had the motobatt.
I think it fried. I read in another thread the charging system can't keep up with the gel Batts.
30 Aug 2021 10:38
Check your rectifier. Motobatt is a good battery and works fine
30 Aug 2021 10:46
Replied by Gr8uncleal on topic Dry v wet cell
Don't forget that there are sealed, wet cell batteries, where you don't need to worry about purchase of the acid.
30 Aug 2021 11:16
- Sneezles61
Replied by Sneezles61 on topic Dry v wet cell
That is what I just put in my RT2... but with only 5 miles so far on it...
I did add a bit more foam to the bottom as the wires looked like they would rub on the tin box..
Sneezles61
Sneezles61
30 Aug 2021 13:16
- 1971DT250
What Sneezles61 said is true. On some of mine I filed small notches in the sides of the battery box so the wires would clear.
The following user(s) Liked this Post: MarkT, Roadking, Sneezles61
- principal282
New rectifier on the way.
oem...
Diode test indicated open on both sides. That may explain a few things...
oem...
30 Aug 2021 14:48
