Stop Switch Assembly 248-82530-02-00 CT3
- ksours
Stop Switch Assembly 248-82530-02-00 CT3 was created by ksours
Restoring an old CT3. The stop switch does not retract on it's own.Went to 2fastmoto but there were sold out of the aftermarket version. Is there a way to take this apart and fix or is it just best to replace?
24 Aug 2021 11:21
Replied by Gr8uncleal on topic Stop Switch Assembly 248-82530-02-00 CT3
You could buy a different (cheaper!) type and just swap over the spring and rod. The thin wire is easily bent, so that you can remove it from the hole in the new switch and replace with your existing one.
24 Aug 2021 11:56
- ksours
Replied by ksours on topic Stop Switch Assembly 248-82530-02-00 CT3
Any leads on other aftermarket versions. 2fastmoto had a nice one but they were out.
24 Aug 2021 12:12
- ksours
Will most 2 wire set ups work as long as long as they mount properly. I am looking at a K&L .
24 Aug 2021 12:37
- Swoop56
Replied by Swoop56 on topic Stop Switch Assembly 248-82530-02-00 CT3
Pretty much any generic switch that fits the mount could do the job .
24 Aug 2021 14:44
- ksours
Thank you
24 Aug 2021 14:52
Replied by RT325 on topic Stop Switch Assembly 248-82530-02-00 CT3
If this is the rear brake switch i'm sure i tried swapping spring & rod on one --maybe not yamaha--& it shot up inside when i took the spring off, so be careful.
24 Aug 2021 16:25
- ksours
worked out great - thx
29 Aug 2021 08:13
"worked out great - thx"
Glad you got it sorted, but what did you do in the end?
29 Aug 2021 08:30
- ksours
Purchased this Yamaha Rear Brake Light Switch Stop Light Switch XS2 XS650 XS750 XJ1100 XS1100 on fleabay. swapped the spring and rod. That easy, thx again.
29 Aug 2021 09:08
