Removing compression release
- yamahahaha
Removing compression release was created by yamahahaha
Picked up a 69 CT1 today and believe it or not someone had put in this compression release.
How do I remove the cable so I can get a socket on to remove. Sorry crappy picture
Replied by MarkT on topic Removing compression release
You'll have to scrape the crud off but there's probably a little allen screw that holds inner cable into lower part.
01 Aug 2021 18:19
- yamahahaha
Replied by yamahahaha on topic Removing compression release
Thanks Mark, ya I know it's dirty. I'm at a slight disadvantage I don't have my usual amenities where I'm currently keeping this bike
01 Aug 2021 18:22
See arrow. Should be a small allen screw that holds in a bare cable. When I was a kid mine was a PITA... once I removed it cable got frayed and it was almost impossible to reinstall.
01 Aug 2021 18:28
- yamahahaha
I'd like to salvage it if possible BUT........
It's no beauty queen .. I just couldn't pass it up being it's a first year for the 175 model
01 Aug 2021 18:32
I wouldn't run it with that spark plug.
01 Aug 2021 19:41
- yamahahaha
How can you see what plug is in?
01 Aug 2021 19:51
Your picture. It looks like an extended tip wide gap hot heat range plug from a Nissan or something from what I can see of the number.
01 Aug 2021 19:56
- yamahahaha
I dont even know whats in it. Just got the bike today. If I had to bet you are probably right. I will check tomorrow for sure
01 Aug 2021 20:04
- yamahahaha
You might be right
