First time leak-down test questions
  • bhepp15
Replied by bhepp15 on topic First time leak-down test questions
Ordered all of the fittings I needed last night so I should be able to test next week!
The following user(s) Liked this Post: MarkT, Andy L
22 Jun 2021 06:09 #11
  • bhepp15
Realized I forgot to order freeze plugs and I am at work and want to get them ordered today. does anyone know what size I need to plug exhaust and carb holes?
22 Jun 2021 14:04 #12
Replied by Andy L on topic First time leak-down test questions
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=223134857174&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • bhepp15
Here’s my setup, got it hooked up late tonight, I attached it to spark plug hole because I couldn’t find a socket to get the other hole opened up. in my excitement I pulled 5psi but I forgot to remove oil injection tube and I didn’t tighten down intake manifold… never do anything in a hurry I should’ve known. Hopefully that doesn’t mess anything up. Anyway it’s too late to continue tonight.
The following user(s) Liked this Post: Andy L
29 Jun 2021 20:17 #14
  • bhepp15
I sat down and did a proper test tonight. Pumped 5psi into it and it dropped to zero in 10 seconds. I could here the bubbling of air coming out so I went and mixed a bottle of good ol soap water together and gave all the seals a good soak. Pumped it back up and what do you know it’s the intake manifold! I’ll have to order a new one and a gasket. Maybe yamabond? I haven’t looked into how that is connected yet
30 Jun 2021 20:17 #15
Replied by RT325 on topic First time leak-down test questions
Interesting for sure but it'll never seal there without the carb holding it flat. Remove that fiber spacer & try again & should be good. In saying that i've never needed to do a vacuum test but looks like you have a good setup there.
30 Jun 2021 23:49 #16
  • bhepp15
I was wondering if the carb was what kept the leak from getting out of control but there definitely seemed to be a large leak along that seal. This one was a pressure test also
01 Jul 2021 05:02 #17
Replied by MarkT on topic First time leak-down test questions
Yes, I agree.  You aren't going to seal that bakelite heat spacer the way you are testing.  You could make a block off plate out of flat 1/4" steel plate and bolt that down in place of carb using gaskets on both sides of spacer instead of using the expandable freeze plug.
01 Jul 2021 05:58 #18
Replied by Sneezles61 on topic First time leak-down test questions
Very easy to trace out the carb... if you can, make it out of aluminum.. quite a bit easier to work with..
Sneezles61
01 Jul 2021 06:26 #19
  • bhepp15
I thought this is what I saw others do but maybe their intakes are setup differently. I don’t have much to do metal cutting with but I can try and figure something out. Where are you saying I should put the gaskets Mark?
01 Jul 2021 06:33 #20
