Painting tank advice
- DT Tim
Painting tank advice was created by DT Tim
I’m just in the process of painting my 400 tank but still unsure what to do where the petcock (fuel tap) fits/seals to the tank.
If I paint the whole area then the oval seal ring from the petcock is sealing onto paint and lacquer, not ideal IMO.
If I leave bare metal it has a chance of rusting.
What have you guys done and any problems with the way you addressed this area?
04 Jun 2021 23:21
- brigsy
Replied by brigsy on topic Painting tank advice
Slap a piece of painters tape over the opening, sit petcock on there and trace in pencil. Then use razor to cut out just inside the perimeter of the oval, just a few mm. That way petcock is sealing to bare metal, wouldn’t worry about rust as much as a leaking petcock ruining a paint job!
68 DT1 003325
09 XT250
09 XT250
The following user(s) Liked this Post: MarkT, 2fishkev, DT Tim
05 Jun 2021 12:14
- Lizeec
Replied by Lizeec on topic Painting tank advice
Replicate how the factory did it, originally that area is painted.
- asco
Replied by asco on topic Painting tank advice
The flatter the area the better. Lower could leak. Higher might be worse? Paint over it. Then' if you are still concerned' - mask the outside perimeter and lightly sand to rough the surface. O rings work as intended.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
05 Jun 2021 13:14
- DT Tim
Replied by DT Tim on topic Painting tank advice
I decided to go middle of the road.......
Etch primed the whole tank then masked off the petcock for primer and color
06 Jun 2021 23:36
- 50:1
Replied by 50:1 on topic Painting tank advice
I have over 100 hours in this gas tank. The petcock rubber gasket lives on top of probably twelve layers of primer, bondo, two part enamel and carnauba wax. Nary a drop of the dead dinosaurs have escaped the seal. The factory did the same.
BTW the oil tank is NOS and the banjo bolt and seals are on the original paint from Japan. They dripped until I added just a schmear of silicone RTV as a last resort. No drips now.
The following user(s) Liked this Post: DT Tim, hackman101
27 Jun 2021 20:13
- Chitter
Replied by Chitter on topic Painting tank advice
curious what is that rear fender, i like it.
15 Feb 2022 05:25
- 50:1
It is an aftermarket plastic fender stitched into a fitted grey plastic fender. Forty years ago. Picture attached.
15 Feb 2022 19:31
