1980 Yamaha DT125 carburetor help needed
- dtlobbster
1980 Yamaha DT125 carburetor help needed was created by dtlobbster
Hi all, I have a 1980 DT125G that I finally got up and running after replacing oil seals behind the stator. But just now I ran into a problem with the carb. The air screw adjustment on my carb is/was completely stripped out and the engine was bogging down (because of a lack of enough air). I tried my best to drill it out with little to no damage and while I got it out, the threads on the and screw are pretty much ruined. If anyone has any aftermarket carburetors that are actually worth buying for this era(oil injected) or where I could find an oem carburetor? I’m having no luck. Or at the very least does anyone know where I could find a replacement air screw?
25 May 2021 16:12
Replied by MarkT on topic 1980 Yamaha DT125 carburetor help needed
Can you post a picture, measurement, something?
25 May 2021 18:05
- Mothersbaugh
Replied by Mothersbaugh on topic 1980 Yamaha DT125 carburetor help needed
Or locate it either on this diagram or in this parts list?
www.partzilla.com/catalog/yamaha/motorcy...80/dt125g/carburetor
Maybe it's me, but I'm not seeing it.
25 May 2021 18:57
1980 had an "tamper proof" carb due to EPA. So original screw was capped and wasn't supposed to be adjusted after it left the factory.
25 May 2021 19:51
- Mothersbaugh
I was remembering that there was a year in which that happened, the EPA intervention, but I couldn't remember which year. That cap is pictured there.
Thanks MarkT!
Thanks MarkT!
25 May 2021 20:49
- dtlobbster
Replied by dtlobbster on topic 1980 Yamaha DT125 carburetor help needed
Yeah that’s the site I tried checking but no avail. It looks like these other guys were right about it being factory locked. Do you know if I 79’ carburetor would work on the 80’? I may have found one I can get off an old parts bike
26 May 2021 08:55
- dtlobbster
Thanks for the info, pretty bummed I tried to pull it out if that’s the case. Do you know if I 79’ would work on the 80’? I may have found someone who I can pick one up from.
26 May 2021 08:57
In 1980 the 125 got a smaller carb and the air filter was redesigned to be much less restrictive than in 78-79.
So to answer your question, the 79 should fit just fine but could need a little tuning? Probably not though. 79 might also have the capped air screw but you can remove the cap and adjust. I've had '79's and one had the cap cap and the other didn't.
26 May 2021 13:34
