Clutch holding tool 73 dt3
- principal282
Clutch holding tool 73 dt3 was created by principal282
Is there a specific tool used to hold it in place while removing/torquing back down? I am gonna get an impact from harbor freight but want to be sure.
I hate to spend money on a tool I will used so sparingly. But I guess people get flat tires etc
73 dt3
73 dt3
02 May 2021 16:24
- tennbamaman
Replied by tennbamaman on topic Clutch holding tool 73 dt3
I bought an electric impact wrench and a metric socket set from harbor freight. It broke the clutch nit and the main gear nut loose without any issue. Im just waiting on my oil seal to come in so i can put it all back together.
The following user(s) Liked this Post: principal282
02 May 2021 16:46
- 1971DT250
Replied by 1971DT250 on topic Clutch holding tool 73 dt3
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=353117923225&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- principal282
Replied by principal282 on topic Clutch holding tool 73 dt3
Electric worked good? I'm looking at an air. But a reasonable priced one
02 May 2021 17:20
- tennbamaman
The electric Chicago worked great for me. I tried the $28 dollar air one but i dont think my air line was large enough. It did not break it loose. I took it back and got the electric as i figured for my needs it would be more consistent and just as easy as breaking out air lines. Hooked it to an extension cord. and it broke them loose without any issue. As stated, both my nuts are broke looses and im waiting on seal to arrive.
02 May 2021 17:27
- tennbamaman
im guessing with the right amount of volume and air, the air impact would have worked as well
02 May 2021 17:28
- 1971DT250
This works great. There are many other brands and larger ones.
www.amazon.com/Milwaukee-2853-22-FUEL-Im...id=1620002367&sr=8-4
I use power tools just to initially loosen. If you spin nuts, bolts and screws too fast it will gall the threads.
- principal282
I went with the porter cable from Amazon tons of torque I wanna say over 500' lbs and about 90 bucks
03 May 2021 07:20
