75 DT-250B carb to head intake manifold vs. 75 RD-250 manifold
- dailyrider
75 DT-250B carb to head intake manifold vs. 75 RD-250 manifold was created by dailyrider
Can anyone tell me if the RD-250 variety, even though it is a twin, would work on my DT ? I have found one on-line, but the seller is unable to provide measurements, bolt hole to bolt hole. The price sure is right, if anyone has
replaced theirs with an OEM, $14.99 for the aftermarket one is a steal , if it fits.
Thank You all.
daily
Thank You all.
daily
27 Apr 2021 19:46
Replied by RT325 on topic 75 DT-250B carb to head intake manifold vs. 75 RD-250 manifold
RD's are a lot smaller. Get on partzilla & compare. Difference should be obvious even in a drawing. I've used a "74 as DT250 is missing in "75 on Partzilla.
www.partzilla.com/catalog/yamaha/motorcycle/1974/dt250a/intake
www.partzilla.com/catalog/yamaha/motorcycle/1975/rd250b/intake
27 Apr 2021 22:26
- dailyrider
Replied by dailyrider on topic 75 DT-250B carb to head intake manifold vs. 75 RD-250 manifold
Thank You, I appreciate it.
28 Apr 2021 05:17
Replied by MarkT on topic 75 DT-250B carb to head intake manifold vs. 75 RD-250 manifold
Yes, the RD manifold bolt pattern would fit the DT125/175...
P.S. Parts list for 75 250/400 on partzilla can be found by looking up 1976... 75 and 76 are combined.
28 Apr 2021 06:15
- dailyrider
Thank You. Just trying to explore some options, might just have to
purchase an OEM version after all...
28 Apr 2021 18:29
- Lizeec
Replied by Lizeec on topic 75 DT-250B carb to head intake manifold vs. 75 RD-250 manifold
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=122017530933&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- dailyrider
Thanks, yeah not through Yamaha. Bike Bandit
www.bikebandit.com/oem-parts/1975-yamaha...0b/o/m7094#sch221477 has it.
28 Apr 2021 19:36
- Lizeec
Bike Bandit has access to genuine Yamaha parts, but I seriously doubt it is available new from Yamaha, I see where it says available and ships in 1-2 days, but if you click on any part for that bike it says it is available and ships in 1-2 days, as an example click on the fuel tank, crankshaft, carburetor, complete fork assembly, rear shocks, frame, swing arm and it will say available and ships in 1-2 days, and we all know 100% for a fact those parts are no longer available new from Yamaha. The only new manifolds I have seen are an occasional N.O.S. for sale on eBay or the aftermarket one I mentioned earlier. My guess is you can try and order it from Bike Bandit and it will not let you pay and check out due to it being no longer available or it will let you pay and check out and take your money then later cancel your order and then refund your money due to it being no longer available again, or maybe they have a secret hoard of parts for that bike, hopefully if it works out for you report back as I am sure others will want to buy new ones at their listed price, either way good luck.
Hot foot moto is about the only place that makes them I think. There used to be a seller in the UK that had nice ones for around $50 but sadly they went out of business a few years ago.
28 Apr 2021 21:51
- dailyrider
Probably true on availability, a lot of stuff is unobtainable right now,
I am considering getting one off of that auction site, there are decent
ones from time to time. However, almost always listed as "has cracks",
if not all the way through (like mine is) I may try to get as decent one
as possible, and perhaps coat it with an epoxy to get the most miles
i can out of it...previous fix was a thin inner-tube rubber strip wrapped tight and
zip tied around manifold.
Has to be a common problem for slot of us ?
Couple of pic's..... I've had this for 10 years, it's just like the one I had
in high school that I always regretted selling. Changed out the fenders
and couple other cosmetic things. It runs and sounds very good and
of course, it's a blast to ride.
01 May 2021 19:05
