1980 Yamaha DT 125 G rpm idling and running problem
On your stock carb, clean it and replace the float needle and seat assembly to stop the overflow leak.  Parts still available from Yamaha or a good Mikuni dealer.
The following user(s) Liked this Post: dtlobbster
05 Apr 2021 21:55 #11
  • dtlobbster
  • dtlobbster's Avatar Topic Author
@ MarkT is the flywheel puller essential to getting the gasket out? Im on a pretty tight budget and was thinking of wraping a belt around then getting the bolt off for the magneto and mabye trying to use tweezers carefully to pull the gasket out and pvc pipe to reseat a new gasket but that might be a bad idea lol. I ordered the part you recommended, does it matter that my bike is a 125? im pretty sure they are the same design as the 175 at least for the crank. Hopefully this is the right fix. Do you have a specific website I should try for the float needle and the seating/gasket? Sorry for all the questions, I'm pretty new to all of this.
05 Apr 2021 22:47 #12
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=254596999090&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=323230114144&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
I'm not sure what "gasket" you're talking about... but no, you need the correct puller or you're likely to damage very expensive parts. Motion Pro is known quality, the no-name cheap ebay pullers can be of questionable quality.sometimes.    Do not try to use a jaw puller on the flywheel.   You will need a hand impact screwdriver or at least a good #3 JIS screwdriver to remove the stator.
Yes, seal is the same on the 125.  I like Rocky Mountain ATV/MC for parts.  www.rockymountainatvmc.com/oem-parts/Yamaha
06 Apr 2021 06:01 #15
  • dtlobbster
@RT325 and @Mark T. I think I found a video of a guy replaing the seal I bought and im hoping if I follow what he did this will solve most of my problems (he did end up shearing the woodruff key)
. So if im correct this (www.motosport.com/product/?cc=us&gclid=C...78-X001-Y007&variant[MOP0078]=MOP0078-X001-Y007) flywheel puller will help me get the parts off. I'll order something to hold the flywheel as well so I can try not to shear the woodruff key. Im also going to replace the needle valve on the OEM carburator. Is there anything I'm missing? thanks for all the help
The following user(s) Liked this Post: TheRiggs
06 Apr 2021 13:26 #16
