RT1 Newb
Replied by Swoop56 on topic RT1 Newb
You can't absolutely rely on the microfishe images that parts suppliers
use . They often combine different years models but don't always
differentiate as to which model had updated parts .
I have a combined RT1/ RT1B parts book from back then .
The decompressor valve was only fitted on the RT1 B .
The RT1 had an advance mechanism on the ignition rotor ,
and  the spark was retarded for startup .
Two different ways to skin the cat .
09 Apr 2021 04:51 #11
  • Geiger
  • Geiger's Avatar Topic Author
Replied by Geiger on topic RT1 Newb
Looks like I have a B model then.
09 Apr 2021 08:26 #12
  • Geiger
Also, I wonder if anyone can give me any starting tips re the decompression lever / valve. Found one on internet but in Japanese.
09 Apr 2021 08:29 #13
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic RT1 Newb
Comparing the engine and frame numbers (if different) with the VIN tables should confirm what model(s) you have. Both numbers will have been the same originally.
Apologies if you have done all of this already!
09 Apr 2021 08:45 #14
  • Gr8uncleal
Are you going to use the original valve? If yes, have a look at the parts manual to see what you are missing and then have a look on fleabay.
Last edit: 09 Apr 2021 08:48 by Gr8uncleal.
09 Apr 2021 08:46 #15
  • Geiger
Sorry if I misled. I have the original front decompression valve and lever etc. All I 'm missing is the rubber type cover. I just wondered if it is a simple as opening the valve before starting and then closing it once running.
09 Apr 2021 12:37 #16
The starting procedure is indeed that simple .
Good luck finding a rubber cover , they are a rare item .
I'm a bit surprised no aftermarket rubber merchant has
repopped one .
09 Apr 2021 14:28 #17
  • Geiger
Now that would be good. I'm trying to find a source to see if they can be 3D printed.
09 Apr 2021 16:38 #18
Replied by MarkT on topic RT1 Newb
The various manuals in the Tech Library explain the starting procedure and a lot of other good stuff!
09 Apr 2021 18:14 #19
  • Gr8uncleal
I seem to recall that Julie(?) from Sumo Rubber was looking for a donor part, with a view to using it as a template to get repops produced. No idea if the original gets destroyed in this process, which is why I haven't volunteered!
I also seem to recall that one of our US friends found a cheap item from a hardware store that could be easily adapted to fit.
10 Apr 2021 00:29 #20
