Replacing steel rims- what to use?
- nhsteve
Replacing steel rims- what to use? was created by nhsteve
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=352221820312&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- 1971DT250
Replied by 1971DT250 on topic Replacing steel rims- what to use?
Be careful about rechroming the original wheels. I have had 3 wheels become unusable after the acid bath due to so much rust that there were perforations through them.
24 Mar 2021 10:53
- nhsteve
Replied by nhsteve on topic Replacing steel rims- what to use?
That is a good point to remember. And it is probably something that would only appear as a problem after the acid bath was completed.
Thanks for the warning!
I did ask the ebay outfit about the steel rims, only info they sent back was that the brand is 'Union Cycle". I need to look that up and see where made (I asked but that question was not answered).
25 Mar 2021 10:38
- Rick C.
Replied by Rick C. on topic Replacing steel rims- what to use?
I have an 18" Takasago rim for a CT front for sale, which just won't do.But something to think about since 19" tires are getting harder to find in certain tread patterns.
- RTD2
Replied by RTD2 on topic Replacing steel rims- what to use?
I have had three rims rechormed and two rejected. A good shop will be able to tell you if they will come out usable. I had two for my Matchless that I desperately wanted to rechrome and they were absolutley too far gone to go through the process.
I used the polishing shop in Oxnard, they outsourced the actual chrome (California is of course very restrictive), but Dave told me very quickly which rims would survive and which would not.
thepolishingshop.com/index.htm
Mike
Mike
25 Mar 2021 11:06
- Swoop56
Replied by Swoop56 on topic Replacing steel rims- what to use?
I bought a replacement Union Cycle front rim for my DT1 .
I bought it as a genuine yamaha part , possibly for an AG 175 ,
if I remember corrrectly .
The downside of them is that the brand and size detail is stamped
onto the outside flange , very much in plain sight .
I didn't fancy that much , so had the chrome stripped , stampings
filled and rim rechromed . The rim itself was inexpensive , but the
follow up work made it a costly exercise .
25 Mar 2021 13:02
- RTD2
Yes, it is not cheap to get it done right.
25 Mar 2021 13:03
- nhsteve
I appreciate the comments, especially the one about having the writing on the outside of the rim- that I do not want.
I think I have come to a decision point with this part of my project. I was able to contact a couple of reputable shops, one in PA and one in RI ( I am in NH). The shop in RI could not handle the rims, but the one in PA (Paul's Chrome) gave me some very interesting info as well as projected costs.
As noted earlier, the rim goes in an acid bath, and if it is pitted too bad it will not be useable (like your Matchless rims). Then the individual pits and dings are addressed and filled as much as possible, and then the chrome is applied. What is significant to me at this point is that the chrome at this point obliterates any manufacturer markings. So if you want them, or need them to be visible for a high-end restoration, then those markings need to be gone over and made deeper by an engraver before the chrome is applied. That way the markings will be seen after the chroming is done. I am pretty sure that a true "restoration" would require this to be done.
So, he gave me a ball-park estimate of about $250-$300 per rim for the renovation/chroming, and another $125 per rim for the engraving. (Earlier this month he had finished a pair of rims for a 1973 Kawasaki Z1 that ran to $1100.) So potentially $900-$1000 for my 2 rims.
With this in mind, I am now looking askance at the total bill from the seller on eBay of $350 to chrome my 2 rims, wondering just what kind of job I will get.
So for now, I think I am going to clean them up as good as I can myself (I can be pretty meticulous and careful). I have stripped the hubs down and will be cleaning them up and polishing the outsides and spoke flanges and clear coat them, then lace up the rims with NOS spokes, and mount the tires. I have 2 older but new Cheng Shin trials tires to mount in the proper sizes. So, not "correct", but period correct anyway.
I'll do my best, and the best I can do is... the best I can do!
Thank you all.
Thank you all.
The following user(s) Liked this Post: Badger52, Snglsmkr, JimA
26 Mar 2021 08:22
- Pillsbury
Replied by Pillsbury on topic Replacing steel rims- what to use?
I always use Aluminum shouldered rims. Not stock but an upgrade & usually accepted as a
replacement. They are about 150-200 per rim. Here is one, please forgive the large front brake
1970 DT1-C Street tracker
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1966 Triumph Tiger Cub
1947 Mustang
1974 Suzuki TC185
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1947 Mustang
1974 Suzuki TC185
- nhsteve
Something I did not consider for this rebuild certainly. And it would have been an upgrade at the time, so a possibility (this is actually what I did for the 360A rebuild, although I was fortunate enough to find useable alloy rims on eBay for that).
I was just on the Buchanan's site and they appear to have increased price-wise to around $275-$300 per rim.
Thanks for the suggestion!
(R5 front brake??)
(R5 front brake??)
27 Mar 2021 08:17
