Stripped screw head on oil pump cover-
- msavitt
Replied by msavitt on topic Stripped screw head on oil pump cover-
i would try to grab it with a small, pointy vice grips laid flat against pump before drilling, banging or chiseling.
this is how I recently losened same screws when it felt too tight for screwdriver
IGNORE ME - I SEE NOW ITS THE CASE AND NOT THE ACTUAL PUMP, DRILL AWAY I SAY!
- run103
Replied by run103 on topic Stripped screw head on oil pump cover-
Get An impact driver and use it enen manually to get case screws out. If they dont come out then take the right tight fitting bit and yap it with a hammer so it seats in the screw and then connect the impact handle and give it a firm hit. This is the best tool ever for frozen screws and bolts
Doug
Doug
08 Mar 2021 12:32
#12
- Grussell
Replied by Grussell on topic Stripped screw head on oil pump cover-
This works good too. A necessity if your going to split the cases and do a rebuild.
1978 DT400
1975 DT250
1976 YZ125X - my post vintage race bike
2022 KTM 300XCW - my race bike
1975 DT250
The following user(s) Liked this Post: Badger52
Replied by RT325 on topic Stripped screw head on oil pump cover-
wonder if these are any good.
www.aliexpress.com/item/1005001707877026...02_,searchweb201603_
08 Mar 2021 20:22
#14
- mdscott
Replied by mdscott on topic Stripped screw head on oil pump cover-
those look interesting
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
09 Mar 2021 08:57
#15
- rodent
Replied by rodent on topic Stripped screw head on oil pump cover-
Sit a 6mm(ID) nut over it and mig weld in the middle and undo with a spanner
09 Mar 2021 10:35
#16
tapping the head of it back into shape with a flat punch works, then get a 'new' Number3 impact tip & tap it into the screw head the with a T bar handle & it'll come out easy. Danger in chizeling around is with long screws you could break out the cover as is a long hole it goes through.
09 Mar 2021 13:54
#17
- Schu
Replied by Schu on topic Stripped screw head on oil pump cover-
Mark Ts post #9
I've done it successfully many times.
I can't image garage life without the hammer type impact driver.
The following user(s) Liked this Post: 2fishkev, Steve F
09 Mar 2021 16:03
#18
- TheRiggs
Replied by TheRiggs on topic Stripped screw head on oil pump cover-
I've had the same problem. I picked up this from the local big box store.
10 Mar 2021 18:01
#19
- principal282
Replied by principal282 on topic Stripped screw head on oil pump cover-
I had luck with both a hammer drill and using a small voice grip and one good whack. I replaced with genuine yamaha screws. Get a jis screwdriver too they make a difference.
10 Mar 2021 18:46
#20
