Is there any hope??
- yamahahaha
Is there any hope?? was created by yamahahaha
Can this be repaired? Would it be worth fixing? It's a Bassani
Replied by RT325 on topic Is there any hope??
Wow that must be thin steel. My thoughts are if the rest of the pipe isn't like that the yes get a bend made up. Have the flange on the end to worry about though or could that be reused & welded on. Realy need to have the pipe on the bike to get the bend made right. My HT1 was very much like that & think i used an old RD350 header as a starting point, good solid pipe.
- MACE6772
Replied by MACE6772 on topic Is there any hope??
Try any race vehicle/ frame fabricators in your area. Drag cars , dirt/sprint cars , most of them fab headers for their cars. Thus they should have access to a box of miscellenous random pre-bent pieces. You might find a piece close to your needs for not alot of $$ without having to buy a whole box full.
01 Mar 2021 13:40
- Schu
Replied by Schu on topic Is there any hope??
This will give you an idea of whether it's worth fixing or not.
Seems a good one isn't cheap anymore.
01 Mar 2021 17:16
Replied by MarkT on topic Is there any hope??
I almost think I can see a weld inside... looks to me like they used a standard mandrel bent exhaust u-bend that was cut in half, rotated a bit, and welded back together.
Measure the size of the tube and the bend radius and you can probably buy a bend and remanufacture the whole head pipe pretty easy?
The following user(s) Liked this Post: yamahahaha
01 Mar 2021 17:37
- shyted
Replied by shyted on topic Is there any hope??
Yes there is ,i'd do it .
there's enough pipes out there to take a lump off one.
Are you welding it or taking to someone?
I crashed my Aprilia RSR 250 racing bike with kit pipes on.
I got them rebuilt . They were bent double and by that time irreplaceable .
Unless you knew what they were, you couldn't tell.
So yes Yamahahaha. have a do .
01 Mar 2021 22:17
