Need Help!!! 73 CT3 175
Replied by MarkT on topic Need Help!!! 73 CT3 175
Found a picture with the bearing installed.
The following user(s) Liked this Post: dallindabus
20 Feb 2021 11:02
#11
- dallindabus
Replied by dallindabus on topic Need Help!!! 73 CT3 175
Any idea what where to buy the bearing? I live in Canada and knots anything isn’t available here, along with the gear I need too. I put a drill on the magneto and removed the spark plugs, spun it a couple times slow to be sure and everything seemed fine. Has spark, moved perfectly, didn’t feel loose, has lots of compression. I’m still not sure about the gears because I can’t get my Carrot Fingers in there. Don’t have a magneto puller and can’t locate the screws.
20 Feb 2021 13:08
#12
Yamaha should have the bearing... but honestly I think you might be looking at a bigger project. It's not likely that just a new bearing will fix it... case is likely messed up as that bearing shouldn't come out like that... could be some internal damage as well... I'd consider splitting the cases and taking a peek inside before buying any parts...
20 Feb 2021 14:16
#13
- dallindabus
I'm trying to take out the motor but I don't know how to takeoff this "side plate" to get the supporting bolt out of the frame and engine do you know how to do that? I'm trying to take out the motor but I don't know how to takeoff this "side plate" to get the supporting bolt out of the frame and engine do you know how to do that?
20 Feb 2021 16:25
#14
- dallindabus
Any idea the size of the needle bearing? Also when I finished splitting the case it looks like a short small needle came out maybe.
24 Feb 2021 04:22
#15
