dt175mx clutch
- Johnnytheboy
dt175mx clutch was created by Johnnytheboy
Hi. Anyone know if a 1979 DT175MX clutch basket can be replaced by a 1980-81 one please?
Part numbers on diagrams are different and was wondering if it’s same size but improved spec
Thank you
Thank you
14 Jan 2021 07:39
Replied by MarkT on topic dt175mx clutch
You'll need to be more specific about what you are looking at or for?
On the US bikes, I've not seen a difference between 78-81 DT175 clutch. Some of the 125's had a shorter basket but 175's are the same. I looked at parts diagram and didn't see a difference there either but I might not understand what part you need.
14 Jan 2021 11:27
- Johnnytheboy
Replied by Johnnytheboy on topic dt175mx clutch
I am looking at changing the whole clutch unit from a 1980 model .my bike is a 78 version
14 Jan 2021 11:48
Should be okay. 78-79 DT125 monoshock had a shorter clutch with less plates. DT175 monoshock all had the taller clutch as well as the 80-81 125.
If you swap assembly, wouldn't matter anyway.
14 Jan 2021 16:58
Replied by RT325 on topic dt175mx clutch
Just check that the clutch cover isn't wider 'stepped out a bit' on the one with the wider basket. Probably just run the same cover on all models.
14 Jan 2021 19:58
- Johnnytheboy
Thanks for all the advice so far .
15 Jan 2021 03:08
