Reply from Rex's speedshop on my stator
  • Bigdog302
  • Bigdog302's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Reply from Rex's speedshop on my stator was created by Bigdog302
here is a quote. Speedshop Sales
11:05 AM (12 hours ago)
to me
Hello
Yes that unit was fully tested, every CDi unit is before we send it so we are confident it is good.
We often see this - old generator windings not being able to fire a brand now CDi unit. Even NOS winding give problems, so its not correct to say the stator is good if NOS windings have been fitted.
Remember Yamaha told dealers to keep parts they removed as faulty when the bike was new and under warranty. This stock would have been put in to store and 40 years later is on sale on ebay as NOS!
Sales Team
Rex’s Speedshop
Are you buying this? I'm not! I will video my results tomorrow, the engine will turn 10,000 rpm with strong spark with the old cdi box installed.
I got the additional cdi box from Rex's and it does not work at all either.
Dave
Jesus is Lord!
Last edit: 21 Dec 2020 21:57 by Bigdog302.
21 Dec 2020 21:51 #1
Replied by MarkT on topic Reply from Rex's speedshop on my stator
Seems like par for the course. Always your fault.
I've had and worked on many later 175 CDI's the past few years... I've never come across a bad CDI box. A couple of bad stators but those were all on the smaller off-road only MX175 ignition which uses a slightly smaller flywheel.
I've seen and tried to fix 175 CDI stators with aftermarket parts (source and pulser coils)... none have ever worked even though ohm readings were within spec.
Really happy that you found NOS parts and got yours to work!!!
21 Dec 2020 22:19 #2
  • Bigdog302
  • Platinum Member
  • Platinum Member
Replied by Bigdog302 on topic Reply from Rex's speedshop on my stator
I only replaced the 2 source coils and the lighting/charging coil assembly and it all works. the bike has a good strong spark on the original cdi box. I will video all this tomorrow God willing.
the only thing that is original on the stator is the pulser coil, I can replace that and there is nos replacements available. I wonder is Enduronut can come and weigh in on this as He was a former Yamaha tech himself. I suspect Rex's statement about Yamaha putting removed warranty repair components back in to the parts bin is false but Enduronut can shed light on this if he is willing.
quote, Remember Yamaha told dealers to keep parts they removed as faulty when the bike was new and under warranty. This stock would have been put in to store and 40 years later is on sale on ebay as NOS!
Dave
Jesus is Lord!
Last edit: 21 Dec 2020 22:54 by Bigdog302.
21 Dec 2020 22:49 #3
  • Bigdog302
  • Platinum Member
  • Platinum Member
I have a non Fresco big one pipe, just big one.
Dave
Jesus is Lord!
Last edit: 22 Dec 2020 15:59 by Bigdog302.
22 Dec 2020 15:53 #4
Replied by Blackhat250 on topic Reply from Rex's speedshop on my stator
Theres a thread in workshop about Rex"s early set-up, where he admitted they never ran right, i offered to trade in against the new set-up , and he declined , So Vape system for me ,,,,
If you aint mixin gas " you aint haulin Ass
23 Dec 2020 14:07 #5
Replied by asco on topic Reply from Rex's speedshop on my stator
Well, I'm sorry. DEET SAVES YOU MONEY ...
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
23 Dec 2020 14:44 #6
  • Bigdog302
  • Platinum Member
  • Platinum Member
Nothing against Deet at all but I rebuilt the stator and it works well with the stock cdi box. it is the Rex cdi boxes that don't work with the rebuilt stator.
The NOS source coils and lighting coil were not all that expensive either, they all were below 70 dollars each with the lighting coil being cheaper than the other two.
The lighting coil needed to be replaced due to a shorted voltage regulator.
The only reason I went with the Rex cdi box was it has a modern more performance oriented ignition curve.
it turned out to be a sacrifice but I can get another stator then send it and a cdi box to Rex's and have them restore the spark. unless Deet knows what is required and saving him a headache, my best option would be having Rex do it.
Dave
Jesus is Lord!
Last edit: 24 Dec 2020 12:55 by Bigdog302.
24 Dec 2020 12:19 #7
I'm sure the reference to "DEET saves you dollars" wasn't a dig on you fixing your own stator.... I think we're all impressed by that! I know I am!
:OnFire :OnFire :OnFire
I took Asco's comment as DEET advocating using caution when buying from Rex's... some people are very happy with Rex's products but the ones that have issues often report the "it's your fault" deflection or just no warranty support at all.
Blaming it on "NOS parts were bad warranty parts the dealer kept on the shelf" is a new twist on "it's your fault" that I hadn't seen before.... :whistle:
The following user(s) Liked this Post: Rick C., Blackhat250, Bigdog302
24 Dec 2020 13:00 #8
  • Bigdog302
  • Platinum Member
  • Platinum Member
Thanks Mark, Rex's is a bit arrogant aren't they? I like their 12 volt conversions as I have one on my DT175, it was easy to install and it works great.
The scary part was both old source coils showed resistance in spec, I determined it was the only thing holding things back by turning the magneto at a faster speed and watch the spark break up.
Dave
Jesus is Lord!
Last edit: 24 Dec 2020 13:57 by Bigdog302.
24 Dec 2020 13:34 #9
It sure seems that way. I have mixed feelings about Rex's. It's AWESOME that they make parts for these old bikes! On the other hand I'm not thrilled with some of the quality/support issues I've seen.
The following user(s) Liked this Post: Bigdog302, Snglsmkr
24 Dec 2020 13:37 #10
