1973 ct3 headlight brackets ?
  • jez
  • jez's Avatar Topic Author
1973 ct3 headlight brackets ? was created by jez
Hi fellas can any one tell me what is wrong here ? is it the ears that are wrong ones or the inserts ? and also does anyone have a picture of the long rubber fuel tank band in its correct position ? thanks for any advice.best regards.. Jez..
19 Dec 2020 05:39 #1
Replied by Pete-RT1 on topic 1973 ct3 headlight brackets ?
Jez, I believe they go on the inside of the headlight bucket with the pip facing inwards.
Yamaha CT3 (in bits)
19 Dec 2020 06:42 #2
Here's the strap on my CT1-B, not sure if this is correct but that was how it was when I got it.
19 Dec 2020 06:51 #3
Replied by MarkT on topic 1973 ct3 headlight brackets ?
Pete has nailed it. The strap can be confusing until you realize it starts and ends on the same pin.
19 Dec 2020 07:58 #4
  • jez
Replied by jez on topic 1973 ct3 headlight brackets ?
thanks for the replies fellas. great pictures, really helpful . do you know what the little pip is for on the insert ?
19 Dec 2020 11:30 #5
Now that you mention it... Something is off here... Don't those washers with the pip have a square protrusion on the back side? Do your headlight brackets have a large hole for the grommet with the square hole?
If so, you might have a non-US model... US models just had a simple bolt-sized hole in the headlight bracket.
I believe the pip on the washer was used to pin a turn signal stalk from rotating. I think same washer was used on rear of some US models to mount signals. Some non-US models had signals mounted to headlight so they probably used that washer there... but you'd need the hole for the grommet in the bracket.
19 Dec 2020 13:04 #6
  • jez
Hi fellas, thanks for your help, these are the parts that i have . any ideas ?
20 Dec 2020 02:26 #7
Replied by Gr8uncleal on topic 1973 ct3 headlight brackets ?
Yes.
The part that you were querying sits on the inside of the headlight shell and the rubber grommet that it sits within protrudes about 1mm inside and outside the headlight shell. The shell sits between the two fork ears, now rubber mounted, and a bolt from the outside, on each side, fixes them all together - check the parts manual for the exact size and washer types.
The road bikes of that era have the indicator mount bolts going through the two holes (I think that MarkT might have mentioned this already).
Edit - a couple of photos of the ones on my RT2 are attached.
Last edit: 20 Dec 2020 03:22 by Gr8uncleal.
20 Dec 2020 03:12 #8
Yes, your picture showing the special washer on top of the headlight bracket threw me off...
Pete's and Alan's description of washer inside the bucket is correct.
20 Dec 2020 05:18 #9
  • jez
Hi fellas ,thanks for all your help . it was the little pip that through me. i can see now how it goes together . cheers. regards. Jez..
24 Dec 2020 05:43 #10
