Tiny bulbs?!
- Glenn77
Tiny bulbs?! was created by Glenn77
Hi guys. I finally figured out why my speedo wasn't lighting up. All of the bulbs except one were blown. DUH! The bulbs are labeled "A6V3W." That appears to be a motorcycle-specific type bulb because I'm having a hard time finding it at the auto and hardware store. Anyone know where to get them?
Also, the oil light bulb was so corroded as to be unrecognizable. Anyone know what it is and where to get it? The service manual doesn't mention anything.
Thanks, guys!
Glenn
Thanks, guys!
Glenn
Had my 1977 Enduro 100 since 1982. My son just dragged it out of the barn.
13 Dec 2020 08:06
- Mike87
Replied by Mike87 on topic Tiny bulbs?!
Ordered some here...
www.amazon.com/Motoparty-Speedo-Speedome...b3RMb2dDbGljaz10cnVl
Search for 6 volt 3 watt bulb motorcycle and you will find some
13 Dec 2020 08:20
Replied by Gr8uncleal on topic Tiny bulbs?!
Just make sure that there is enough bare metal in the oil light bulb socket to ensure a good connection - I've had mine just dipped into Evaporust for 24 hours to get rid of the worst of the corrosion.
13 Dec 2020 09:37
Replied by MarkT on topic Tiny bulbs?!
All 4 bulbs are the same according to the parts lists you can find online and are available at your friendly Yamaha dealer... online or local.
Eiko is also a popular brand if you look on Amazon or ebay... there is a version with a larger glass globe that won't fit in the hole so be careful there.
What you're seeing is common on a bike without a voltage regulator and say a good battery... a little imbalance and lights start to blow. Would be a good idea to add a voltage regulator since 6v bulbs are harder to find (and more expensive!) than they used to be.
13 Dec 2020 09:38
- Rick C.
Replied by Rick C. on topic Tiny bulbs?!
13 Dec 2020 09:42
- yamahahaha
Replied by yamahahaha on topic Tiny bulbs?!
13 Dec 2020 09:52
