DT1 sprocket carrier bearing replacement
- type one
DT1 sprocket carrier bearing replacement was created by type one
Help & knowledge needed please
How is this bearing removed ?? Specialist press needed?
What size and specification details do I need to locate a replacement??
T1
T1
DT1's mainly -
1968 AUS
1969 B scabby track bike
1969 B MX project
73 CT3 project
BMW GSA 2018
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
05 Dec 2020 11:06
- Swoop56
Replied by Swoop56 on topic DT1 sprocket carrier bearing replacement
The bearing will knock out with an appropriate drift . If you heated it in an oven
( when your missus isn't around ) , it might shift easier . I'm guessing it's for a
DT1 B , if so the bearing is a 6204 . I'd use a double rubber seal example .
They are readily available at bearing suppliers ( SKF , SAECO , NTN ) .
05 Dec 2020 11:47
- type one
Replied by type one on topic DT1 sprocket carrier bearing replacement
Thanks Swoop
Out of interest how hot oven temp wise?
150 degrees C?
Cheers
T1
150 degrees C?
Cheers
T1
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
07 Dec 2020 06:30
- Swoop56
That's probably fine . I've always done them cold myself .
Some people heat heat engine cases when installing main bearings / cranks .
I would guess a similar temperature would work . Hopefully someone else will comment .
07 Dec 2020 11:29
- type one
It worked a great ... thanks
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
The following user(s) Liked this Post: MarkT, Swoop56
07 Dec 2020 12:01
