Nineteen seventy ? DT100
  • DavidMalt
  • DavidMalt's Avatar Topic Author
Nineteen seventy ? DT100 was created by DavidMalt
Hello, Recently obtained a DT100. Very original looking bike, last registered in 1983. Trying to breath some life into this gem after 37 years of neglect.
No paperwork, lower section of the frame tag is worn, can't figure out exact year/model.
its either a 78 or 79, and letter designation unknown ( dt100 a,b,c,d, etc. )
Kick starter busted, and basically every electrical item was suspect upon further inspection.
-Battery toast ( obviously lol )
- headlight/tail lamp burnt
- diode rectifier melted
- rear tail harness shredded by tire
-no spark, no voltage from ignition source coil
-gauge lights burnt
-ignition coil primary winding shorted
-points and condenser bad, someone stripped one of the main stator assembly screws.
So far i have replaced
-tires and tubes
-headlamp/tail bulbs
-gauge bulbs
-points/condensor
-ignition coil
-diode rectifier
Now gets power at coil + and battery + when kicking, but no headlamp or neutral light
Tail lamp and gauges will light up with key on.
Bike will still not start.... no spark. possible bad new coil. thinking of going CDI ignition, not sure.
looking for a proper wiring diagram, the 76 dt100 diagrams do not match this bike. seems like a transitional year bike.
Also whats the deal with dt100 a b c d etc.?
03 Dec 2020 17:59 #1
Replied by MarkT on topic Nineteen seventy ? DT100
Looks like a nice project... the points are a great system in my experience so I wouldn't give up on them.
Check the VIN in the Tech Library here to confirm the year... might have a manual there too.
In the USA, 1974 was the first year Yamaha called everything a "DT". So 1974 was "a", 75 was "b", 76 was "c" and so on... yours is probably a 1978 (e) or 1979 (f).
The following user(s) Liked this Post: DavidMalt
03 Dec 2020 18:06 #2
  • DavidMalt
Replied by DavidMalt on topic Nineteen seventy ? DT100
Thanks for the heads up. Looking for manuals to purchase, was not sure why the letter designation.
vin is 2f5-3104, ill check the site cross reference
03 Dec 2020 18:11 #3
  • DavidMalt
03 Dec 2020 18:39 #4
Replied by Bigdog302 on topic Nineteen seventy ? DT100
That is a 1978 DT100. it shares the same colors that a Sunshine Red 1978 DT175 has.
Dave
Jesus is Lord!
03 Dec 2020 19:37 #5
  • DavidMalt
Now armed with an accurate wiring diagram I dove into the harness and located a few shorted wires, and flasher relay shorted too.
Hard to spot but all the small kinks are fried sections of loom
03 Dec 2020 21:59 #6
  • DavidMalt
Yes mystery solved. Didn’t realize red color was a one year option until directed to the site tech articles. I Attached the findings above for future reference.
03 Dec 2020 22:07 #7
