75 or 76 DT250
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic 75 or 76 DT250
Single yellow/white might also be from voltage regulator.
24 Nov 2022 09:55 #11
Replied by Liebherr on topic 75 or 76 DT250
It’s a 1975 512 wire is out of the voltage regulator
bolted to the air box see photo
There is only 3 wires coming out of the magneto
24 Nov 2022 10:30 #12
  • Gr8uncleal
In that case it will plug into a female bullet connector of the same colour coming out of the main harness. Have a real close look and see if it has been cut off, taped over or maybe even plugged into a wire of a different colour. Assuming that the main harness hasn't been removed and refitted in the wrong position, then the wire you're after will be within easy reach of the one from the regulator.
24 Nov 2022 10:44 #13
Thanks, i will let you know how i get on with the rewire
26 Nov 2022 05:13 #14
