Fuel tap repair kit
Replied by MarkT on topic Fuel tap repair kit
Does it matter what the throttle opening is when it "bogs down" at 5,000 RPM? (You should be able to rev to redline at very low throttle openings)
If not, then it's an almost certainly an ignition issue.
18 Oct 2020 07:36
#21
- wayno
Replied by wayno on topic Fuel tap repair kit
Cannot get the bike out now(in work) but it bogs down in top gear rolling the throttle on and also in lower gears accelerating hard
18 Oct 2020 08:49
#22
- wayno
Just tried the bike revs to between 5-6k revs before starting to bog at a 1/4 throttle.
- DEET
- Moderator
Replied by DEET on topic Fuel tap repair kit
You shelled out a lot of money for the CDI system... why not give them a ring and ask them what is wrong?
Or ask them for a replacement.
18 Oct 2020 16:32
#24
- wayno
Rang them this morning, said I had a problem, just said send it back, didn't seem interested in what was wrong until I made a point of telling him then said sounds like carburattion. Carb been checked twice and is ok, going to whip it off later.
19 Oct 2020 01:34
#25
- DEET
- Moderator
Hopefully they will send you one that works.
19 Oct 2020 06:06
#26
- asco
Replied by asco on topic Fuel tap repair kit
May I Suggest A new STICKY:
Rex's Speedshop Horror Story's
Ignitions that don't work/
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
20 Oct 2020 09:51
#27
