Oversize piston
  • likaroc20
  • likaroc20's Avatar Topic Author
Oversize piston was created by likaroc20
I have a 1977 D100. Currently it has a stock piston but I would like to install a 1.75 oversize. Can the stock sleeve be bored to accept the oversize or will I need a different sleeve? Thanks in advance.
26 Sep 2020 16:54 #1
Replied by yamahahaha on topic Oversize piston
Yamaha piston sizes start at standard .00 1st over.25 THEN 2nd over .50 THEN 3rd over .75 THEN 4th over 1.00 which is 4th oversize... In my opinion I prefer not to go past 1.00 oversize.... The more you exceed you are asking for trouble shaving the cylinder wall THINNER and THINNER.... JMHO
The following user(s) Liked this Post: likaroc20
Last edit: 26 Sep 2020 17:52 by yamahahaha.
26 Sep 2020 17:35 #2
  • likaroc20
Replied by likaroc20 on topic Oversize piston
I didn't realize that. The 1.75 is a piston I saw for sale on a local forum. I'll stay away from going that oversize. Thanks very much!
26 Sep 2020 17:39 #3
Replied by Pedalcrazy on topic Oversize piston
If you think you need a new piston you need a machine shop to check out the cylinder. They will tell you what size of overbore will clean up the cylinder. You can't tell by just looking. Maybe it will take a third of fourth oversize or maybe just a hone and new standard piston. If you don't have it professionally examined your going to toss time and money up in the air. Just my experience anyway. I thought my RT1B cylinder looked good...no bad scuffs....however the cylinder was ovalled out at the bottom and took 2nd oversize to make it all round again. I never would have suspected that with the naked eye.
26 Sep 2020 18:05 #4
Replied by MarkT on topic Oversize piston
Go only as much oversize as you need to.
Boring it as big as you can won't give you any noticeable power increase... in fact, you OFTEN lose power with a two stroke because the port size and timing changes as the bore is increased... you'll need to port the cylinder just to get back to stock specs.
26 Sep 2020 18:12 #5
Replied by Rick C. on topic Oversize piston
It's a dance.
Got any pictures you can show? Top of the piston and such. yeah, clean it so we can see the numbers, may not need it.
Let's not go crazy yet.
Let us help on this.
Reason being, if you have a standard piston, the setting you want will be a waste of cylinder to no reason.
Listen to these guys . I have been for years and years.
Last edit: 27 Sep 2020 21:19 by Rick C..
27 Sep 2020 21:15 #6
Replied by RT325 on topic Oversize piston
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=153060925255&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • likaroc20
Thanks for your message. Here's a few pictures. This piston and head came from a parts bike and I thought it a good idea to change out the piston and rings before I put the engine back together. What does the piston look like to you? Does that burn mark mean anything?
28 Sep 2020 05:51 #8
  • likaroc20
Thanks for the message. Yes, a DT100.
28 Sep 2020 06:37 #9
