Soot on front fender-still learning
- Timcat
Soot on front fender-still learning was created by Timcat
Hello, I noticed after rides on my 72'RT 360 there is soot on the rear of the front fender. Is this normal or due I need a new gasket, or should I be more concerned and this is a more serious issue? Thanks Tim
24 Aug 2020 14:52
- 1971DT250
Replied by 1971DT250 on topic Soot on front fender-still learning
Not unusual. A new string gasket will make it better. Be sure to clean out the old one. You can take the manifold off and separate the inner piece from the outer but the 2 bolts are likely rusted in the cylinder. Easy to break them. The string gasket is available, I use 2 loops. It may still spit a little.
24 Aug 2020 15:09
- Timcat
Replied by Timcat on topic Soot on front fender-still learning
24 Aug 2020 15:13
Replied by MarkT on topic Soot on front fender-still learning
I'd like to add to check and make sure it's not the head or base gasket leaking... but usually it's normal.
24 Aug 2020 16:14
