Steering Damper
  • carter6787
  • carter6787's Avatar Topic Author
Steering Damper was created by carter6787
I have dismantled my RT3 ready for a full restoration and was keen to see what is inside a steering damper.
I carefully unscrewed the six screws holding it together waiting for the oil to gush out but look what I found!
Completely dry and crud inside. Will vapour blast it, put in new o-rings and screws and it should be for another forty years!
04 Aug 2020 22:02 #1
Replied by Rick C. on topic Steering Damper
How's the wiper?
Last edit: 04 Aug 2020 22:24 by Rick C..
04 Aug 2020 22:06 #2
Replied by MarkT on topic Steering Damper
Should have been full of oil
05 Aug 2020 05:46 #3
Replied by Yamrt3 on topic Steering Damper
What is the recommended oil for the damper and how much should be in there?
05 Aug 2020 09:23 #4
Replied by 1971DT250 on topic Steering Damper
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=173665603071&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by KennyV on topic Steering Damper
Yep, +1 on the DEET kit. When disassembled my RT2 damper it was the same, empty. After 40+- years no surprise. I thoroughly cleaned and rebuilt with the DEET kit and no leaks all's good. I did use (I think, I'm old and memory not so good) 10W fork oil. If I were to do it again I would go with a heavier weight oil.
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
05 Aug 2020 13:56 #6
Replied by Pedalcrazy on topic Steering Damper
05 Aug 2020 14:27 #7
Replied by RT325 on topic Steering Damper
They can be a bit imprecise with wear in the splines & clearance on the bit on the frame. I tapped one of mine to 6mm & drilled the 6mm thread out of the steering yoke. Then ran heavy oil & damped too much riding down the road like a noddy. So took it off haha. They wear in the body where they come through the top & move in the bottom bit especially if run dry--& yours sure is dry.
05 Aug 2020 15:15 #8
Thanks for the info, I've just ordered the rebuild kit. I also have dif oil for my Goldwing, I'll use that. I ride mostly on hard surface as well a few dirt trails. Thanks again.
05 Aug 2020 15:49 #9
