To line or not to line tank
- meadeam
To line or not to line tank was created by meadeam
I de-rusted my tank last summer before letting the project languish until just recently. I had fogged the inside of the tank with WD-40 before I put it up, so it hasn't gone completely to heck. I planned to toss in some hard media and acetone and shake it clean again. I don't think I'll ever get it to shiny metal, but I will get all of the loose stuff out. Should I line it? I have a Caswell liner kit I am on the fence about using because I'm worried about it coming off and causing bigger problems.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
1975 RS100
2007 FZ6
Fort Thomas, KY
05 Jun 2020 07:28
Replied by Gr8uncleal on topic To line or not to line tank
My instinct is not to line.
It has worked for some, but I have also read some horror stories.
I think that the original tank tap should have a filter on it and you can add an inline filter - I'd go with that set up, at least to start with.
05 Jun 2020 07:35
- mdscott
Replied by mdscott on topic To line or not to line tank
I agree, run for awhile, if you start to see a lot of crud in the filter then line it. As far as Caswell, it’s my go to and it’s on several of my bikes and no issues, I think it’s the best, IMHO.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
05 Jun 2020 07:41
- meadeam
Replied by meadeam on topic To line or not to line tank
Thanks, yeah, my instinct is not to line unless it leaks or is too cruddy. I have a couple filters on hand.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
1975 RS100
2007 FZ6
Fort Thomas, KY
05 Jun 2020 07:57
Replied by MarkT on topic To line or not to line tank
I'll only line a tank if it has pinholes and I can't find a better one.
05 Jun 2020 08:35
- mdscott
Like MarkT says. I know you have a metal tank, but for reference if its fiberglass it has to be lined. Modern gas destroys it.
I had a really bad tank on my MX250, swiss cheese and holes all over the bottom. I ended up fiberglassing the bottom outside of the tank and heavly lined the inside. I probably should have found another tank, after finished with all the fiberglass and liner it was very heavy.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
05 Jun 2020 09:07
- meadeam
I ended up shaking it for 10-15 minutes with a cup of sheet metal screws and acetone inside. After that I did a few cycles of adding a small amount of gas, shake-shake-shake, drain into a jug, repeat until gas comes out clear. During that process the reserve outlet in the petcock clogged once (petcock wasn't installed for the sheet metal screw phase). I think all the loose bits have been chased out now. The main outlet has a filter, and I will run an inline filter as well.
I don't know how I can get it much better. I am tired of messing with fuel and chemicals. Anything further and I think I'll look for someplace to send it away to be re-furbished.
1974 DT360
1975 RS100
2007 FZ6
Fort Thomas, KY
1975 RS100
2007 FZ6
Fort Thomas, KY
- swm
Replied by swm on topic To line or not to line tank
meadeam,
I'm in the Mark T camp of "no liner" unless there are pinholes in tank. If heavy rust I shake w/nuts & bolts as you have done. Then I soak w/Metal Rescue as it removes all rust. This time of year I place tank outdoors as MR works faster in warm temps. MR is approx $25 per gallon at Home Depot or Lowes. I typically use 2 gallons and flip tank later to ensure every crevice is rust free. Not much effort involved since you've completed the nut/bolt shaking. I remove petcock during process to keep crud out, but MR is non-toxic & does not harm paint, rubber, your hands, etc - just the rust.
Best of luck!!
Best of luck!!
The following user(s) Liked this Post: meadeam
08 Jun 2020 10:01
- run103
Replied by run103 on topic To line or not to line tank
I used red coat after a muratic acid wash and did 2 coats and let it cure for 6 weeks
It seems to be working pretty good after 2 years. Doug
08 Jun 2020 10:24
