flywheel interchangeability
  • elliottles1
  • elliottles1's Avatar Topic Author
flywheel interchangeability was created by elliottles1
good day,
could anyone please tell me if the flywheels on 77/78 dt400 are interchangeable with 75/76? both are cdi. I have F3T350 on my 78 but need swap it out hopefully with a F3T30072.
any advice appreciated.
cheers
les
18 May 2020 06:00 #1
Replied by MarkT on topic flywheel interchangeability
If you mean does it fit the crank? Yes.
You do need the flywheel that matches your ignition though.
18 May 2020 06:03 #2
  • elliottles1
Replied by elliottles1 on topic flywheel interchangeability
Mark T,
thanks for the response. yes I was hoping to fit one from a different cdi year. I assume that the trigger timing is the reason that they have to match the stator ?
les
18 May 2020 06:23 #3
You're probably talking about Rex's? That would be my guess... they would be the ones to ask.
18 May 2020 07:10 #4
  • elliottles1
me again,
no, not rexs. I have a 78 dt engine with cdi stator, but no flywheel. I have access to one from a 75/76 and wondered whether the stators were similar enough that the alternative flywheel would work.
any ideas?
les
18 May 2020 09:37 #5
I don't know. I doubt it as they were completely different ignitions. DEET might know.
18 May 2020 12:53 #6
Replied by RT325 on topic flywheel interchangeability
I'll take a guess & say No as early flywheel "i think" has a notch on the center part that might trigger the pulser "guessing". But not sure if the same applies with the later different trigger. Sorry that was no help was it.
18 May 2020 19:33 #7
Replied by Makotosun on topic flywheel interchangeability
It should physically fit, but the ignitions are different (different CDI trigger). Partzilla shows them as being different part numbers.
19 May 2020 05:45 #8
  • elliottles1
me again,
for the few quid that it is I'm gonna buy this one and try it, I have convinced myself that it is actually from a similar model, the seller now says he does not know which model as it came to him as scrap.
the flywheel that belongs on my bike is "F3T350" and the one I will buy is "F3T30072", they are both F3T
if anyone can shed light on that I appreciate it. if not, I will let you know in due course!!
cheers
les
19 May 2020 05:52 #9
"F3T30072" is from a 1977 DT400. Should work.
19 May 2020 06:38 #10
