AutoLube Plastic feed line
- mdscott
AutoLube Plastic feed line was created by mdscott
Hello, Yamaha Enduro fans.
I meant to say output, from pump to carb.
I need a few opinions, my YG5T uses a plastic AutoLube output line.
The bike came with fiber washers, Yamaha only sells copper. I have both types,
I need some input on which you would think be best.
Personally I believe fiber is best, I don't think copper would be good against the plastic tube.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
- DaveR
Replied by DaveR on topic AutoLube Plastic feed line
I would use some thick gasket material and Hollow Punch Set from Harbor Freight to make some.
Fiber would be my next choice. not sure about the what looks like a knurled finish on the ones you have ?
02 May 2020 11:47
- mdscott
Replied by mdscott on topic AutoLube Plastic feed line
Thanks.
I've used the red fiber gaskets with similar things with success.
I do have the HF hole punch set. Probably could find a doner gasket.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
02 May 2020 12:01
Replied by MarkT on topic AutoLube Plastic feed line
I'd use the fiber ones.
02 May 2020 12:50
- DEET
- Moderator
Replied by DEET on topic AutoLube Plastic feed line
What happens if you use too thick a gasket?
What happens if you use the wrong banjo bolt? (The new ones are not the same as the originals)
The spring has to rest against the top of the banjo bolt.
I do not recommend making your own gasket if it will be too thick. The originals were thin.
The following user(s) Liked this Post: swm, mdscott, Dirtboy, JGersh, JayB, Snglsmkr
- mdscott
Thanks DEET, do you know the thickness of the gasket?
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
02 May 2020 19:17
- DEET
- Moderator
If someone has a new copper gasket, you could measure it.
The fiber shouldn't be much thicker.
Most gasket material today is too thick.
02 May 2020 20:17
- mdscott
Thanks for getting back. I have new copper ones from Yamaha, I’ll measure them. I’ll post results tomorrow. Thanks again DEET.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
02 May 2020 20:48
- mdscott
factory yamaha autoLube copper gasket is .50mm, or .020"
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
03 May 2020 20:19
- DaveR
Used ones off a 1971 CT1 measure .063mm thick, black gasket material type.
04 May 2020 11:35
