Carb rebuild kit
  • dwil4
  • dwil4's Avatar Topic Author
Carb rebuild kit was created by dwil4
Anyone ever use this kit for a CT2??
19 Apr 2020 00:19 #1
Replied by MarkT on topic Carb rebuild kit
Hit and miss. Lots of problems have been caused by using those kits.
Gaskets and float needle are often okay... other parts like the jets they provide are of dubious calibration. Newer AT/CT versions don't seem to have correct gaskets sometimes.... check photos carefully.
Unless torn or badly damaged... OEM bowl gaskets can be reused. If needle and seat is bad, new Mikuni parts are readily available from places like Niche Cycle or Yamaha. For jets, again, genuine Mikuni but rarely "need" replacing.
O-ring on jet setter, best is Mikuni/Yamaha... (this o-ring is the only thing that usually "needs" replacing.)
The following user(s) Liked this Post: yamahahaha
19 Apr 2020 06:52 #2
  • dwil4
Replied by dwil4 on topic Carb rebuild kit
Part #5 ?
19 Apr 2020 10:13 #3
  • Snglsmkr
  • Snglsmkr's Avatar
Replied by Snglsmkr on topic Carb rebuild kit
Yes, item 5 is the O-ring MarkT is referring too. If you have a gravel driveway, I recommend you buy two. :whistle:
The following user(s) Liked this Post: MarkT, mdscott, Schu
19 Apr 2020 13:31 #4
Replied by Schu on topic Carb rebuild kit
:ROFLOL :ROFLOL :ROFLOL
It's true.....
The following user(s) Liked this Post: MarkT, Mothersbaugh, Snglsmkr
19 Apr 2020 13:54 #5
Replied by Tomoko on topic Carb rebuild kit
Becareful you don't buy a Chinese reproduction...we bought one for my bike for 30 bucks and the carb actually split in half right down the middle. like fell apart. No kidding. Lol
24 Apr 2020 13:40 #6
Replied by Papawhellie on topic Carb rebuild kit
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=322799805872&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
