1971 DT1 MX Restoration Question
  • dk3966
  • dk3966's Avatar Topic Author
1971 DT1 MX Restoration Question was created by dk3966
I have a 1971 Yamaha DT1 MX that I am in the process of restoring. When I got the bike mostly apart I noticed that the side (kick) stand was touching the swingarm when the bike was up on a MX stand. I never noticed it before. Should the sidestand be rubbing the swing arm? I assume not. Does anyone have any experience with this issue? If so how did you fix it?
16 Apr 2020 10:35 #1
Replied by Schu on topic 1971 DT1 MX Restoration Question
My DT400 does the exact same thing. For now I simply found a large rubber washer that I slipped over the foot of the kickstand to acts as a damper between the stand and the swing arm. My future plan is to have my son put a spot of weld on the pivot tab so that I can take a grinder and shape the bead of weld to act as a raised position stop, preventing it from pivoting all the way against the swingbarm.
16 Apr 2020 10:46 #2
Replied by DEET on topic 1971 DT1 MX Restoration Question
The kick stand is traveling too far back.
You can build up the metal with a welder in one of these two locations.
16 Apr 2020 10:51 #3
Replied by KennyV on topic 1971 DT1 MX Restoration Question
I had simular problems with my RT kick stand. The bracket for mine had been broken sometime in the past and welded back on. I ground out the old weld, welded back in position and added weld the bracket to stop the kick stand in the correct position up and down.
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
16 Apr 2020 10:56 #4
Replied by MarkT on topic 1971 DT1 MX Restoration Question
Also commonly happens if someone installed slightly longer shocks... fix is the same.
16 Apr 2020 11:08 #5
  • dk3966
Replied by dk3966 on topic 1971 DT1 MX Restoration Question
Thanks for the input. I had come to that same conclusion buts it really helps to get some advice from people who have been there done that.... Thanks Again All......
17 Apr 2020 05:54 #6
