Does a 1974 Yamaha DT175 have a voltage regulator?
  • JohnPaul
  • JohnPaul's Avatar Topic Author
I keep blowing bulbs at high revs and sometimes low revs and I can't get the lights to come on steady (i.e. getting brighter when revving} I have looked and looked and cannot find a regulator anywhere on this bike or on the manuals. Someone help please!
18 Feb 2020 09:38 #1
Your wish is our command! See link below regarding retro fitting of 6v voltage regulators.
yamaha-enduros.com/index.php/service-bul...e-voltage-regulators
18 Feb 2020 10:20 #2
This may help.....
18 Feb 2020 10:27 #3
  • JohnPaul
DEET... you're a legend.
The following user(s) Liked this Post: DEET, Rick C.
18 Feb 2020 10:41 #4
  • JohnPaul
Hey deet, what year is that paper from? I think I don't have a voltage regulator.
18 Feb 2020 11:47 #5
Partzilla shows the 1976 DT175C as the first one to have a voltage regulator fitted as standard, hence Yamaha's own bulletin that I posted the link for. :likey
18 Feb 2020 12:10 #6
My 1975 DT 175 has a voltage regulator. It's under the tank in front of the flasher.
I take that back it is a rectifier.
Last edit: 18 Feb 2020 17:36 by JimA. Reason: I was wrong
18 Feb 2020 17:25 #7
  • JohnPaul
Would you mind sharing a photo?
18 Feb 2020 21:00 #8
The Rectifier ( diode) is actually above the flasher with the red and white wires. It is not a part of the head light wiring.
18 Feb 2020 22:47 #9
..........and shouldn't be confused with the voltage regulator that you are enquiring about.
The following user(s) Liked this Post: RT325, JimA
18 Feb 2020 23:53 #10
