yamaha 5LT Restoration
- s900t8v
Replied by s900t8v on topic yamaha 5LT Restoration
Has good compression
Yamaha l5t
Gear selector lever
Battery
Tyres
Chain
tank badges
Seat
Left side cover
Choke lever
Tyres
That’s the main things.
I’ll make the cables myself.
Zinc phosphating the tank now. Will start cleaning up the geese and stuff.
Yamaha l5t
Gear selector lever
Battery
Tyres
Chain
tank badges
Seat
Left side cover
Choke lever
Tyres
1976 Yamaha AG175 cafe
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
11 Jan 2020 14:59
#21
- s900t8v
Yamaha l5t
Gear selector lever
Battery
Tyres
Chain
tank badges
Seat
Left side cover
Choke lever
Tyres
Yamaha l5t
Gear selector lever
Battery
Tyres
Chain
tank badges
Seat
Left side cover
Choke lever
Tyres
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
11 Jan 2020 14:59
#22
- Makotosun
- Administrator
Replied by Makotosun on topic yamaha 5LT Restoration
It is a 1968 YL2-c. We have specs and a downloadable factory manual at this link:
yamaha-enduros.com/index.php/workshop/wiki/1-enduros/3-yl2c
11 Jan 2020 17:05
#23
- GFrench
- Supporting Moderator
Replied by GFrench on topic yamaha 5LT Restoration
1971 DT1F MX 250
1973 RT3 360 "Black Widow"
1973 RT3 360
1976 IT 400 / redesigned as a 75 MX400
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: Makotosun, Snglsmkr
12 Jan 2020 08:55
#24
- Noviastar
Replied by Noviastar on topic yamaha 5LT Restoration
Well looks like a labor of love. Im poking around for a double seat. if i find one that fits i can let ya know. as you seem to be seat-less.
Good news is a lot of fiddly bits are still available on parts web sights. Ebay seems to have a bunch of bits to.
OH and i scored a L5T official shop manual.
so if you have any questions i can look up info and "quote from the good book".
12 Jan 2020 10:58
#25
- s900t8v
Hey thanks for the kind offer.
These must have been common in Thailand and there are heaps of NOS parts on eBay and some others including seats and things so that’s good.
Yesterday I pressure washed it down and cleaned out the carb side of the engine and the intake piping.
The rubbers are rock hard and the paper air filter had disintegrated. I guess I’ll put an aluminium flange into the airbox and install an oiled foam air filter in the airbox.
Crazy design how the carburettor is inside the side cover and it draws air in the side cover so the side cover has to be sealed to keep dirt out.
Perhaps that meant less dirt and mud got into the carb pretty cool although there is a mesh drain hole st the bottom of the side cover so if you drowned it it would have filled up.
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
12 Jan 2020 13:07
#26
- s900t8v
Yamaha l5t
Gear selector lever
Tail light
Battery
Tyres
Chain
Horn
Air filter
Left side cover
Side cover knob
Fork gaiters and seals
Oil sight glass
Seat
Mirrors
Clutch lever
Brake lever.
tank badges
Choke lever
Brake pads
Speedo o ring
Globes
Blinkers
Here’s my updated shopping list. Going to make sure it runs before I go splurging. But needs quite a few parts to get it roadworthy.
Metal finished a few dents yesterday too. Just little things to have a bit of fun.
Cleaned out tank and fuel tap
I will put a battery and new spark plug in next and try it with a bit of fuel
Think it’s going to be loud with the stock exhaust dos the baffle I think has been smashed out.
Is there a cheap alternative for oil tank sight glass. My plastic has rotted and is leaking.
Gear selector lever
Tail light
Battery
Tyres
Chain
Horn
Air filter
Left side cover
Side cover knob
Oil sight glass
Seat
Mirrors
Clutch lever
Brake lever.
tank badges
Choke lever
Brake pads
Speedo o ring
Globes
Blinkers
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
Replied by MarkT on topic yamaha 5LT Restoration
Carb is on the side of the engine because it's a rotary valve design... there's a spinning disc that opens an closes the intake port. Yamaha called it a "rotary jet"... Disadvantage is the width of engine... advantage is it was the most powerful two stroke design that wasn't super "peaky" like the high performance piston port designs.
Oil tank window is still available... fits a lot of enduro models. www.partzilla.com/product/yamaha/214-21761-00-00 Not very expensive.
12 Jan 2020 13:44
#28
- s900t8v
Oh thanks mark forgot about partzilla!
Random question. On speedo is 4 indicator lamps
N is neutral
F I presume is flasher
C is ??? Charging ? Battery indicator ?
H is high beam I think.
Is that right ?
Also I have ignition key but it does not fit tank or steering lock. I am thinking that is a different key. The code is stamped on steering lock. Would Yamaha still be able to cut me a key or where should I look for that ?
Also what chain does it run. Is it a 420. Couldn’t find that in the manual.
N is neutral
Is that right ?
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
Owner's manual is in the Tech Library.
yamaha-enduros.com/index.php/ownders-man...9-l5t-owner-s-manual
It should tell you about the lights but what you said sounds right.. If you can't find the chain specs, check Partzilla.
The following user(s) Liked this Post: s900t8v
12 Jan 2020 14:42
#30
