EARLY YAMAHA'S 1959 -63 YDS's
- swm
Replied by swm on topic EARLY YAMAHA'S 1959 -63 YDS's
Clegg,
Here you go.... I put these in my YDS3's, same part # as your YDS2. You get 5 friction plates for $68.16.
Good luck,
swm
www.barnettclutches.com/1143/yamaha/0/0/...-yamaha-yds2-3c.html
- Clegg
Replied by Clegg on topic EARLY YAMAHA'S 1959 -63 YDS's
Thank you!
09 Apr 2020 13:29
#292
- avc2020
Replied by avc2020 on topic EARLY YAMAHA'S 1959 -63 YDS's
Hello,
I'm new to this site.
I just received the clutch kit from Barnett and it comes with 5 friction discs and my original YDS3 has 4.
Can anyone assist on how they made this work. The original friction disc are measuring just under 4mm.
The new friction discs are 3.54mm. If I add a steel the clutch pack would be over 2mm thicker than the original.
I think that is to much to remove from the plate
Also I have a YDS3 vin# Y23-23257. can anyone help me identify the actual year? I was told its a 1966
Thanks!
Thanks!
28 Aug 2020 12:22
#293
- yamahahaha
Replied by yamahahaha on topic EARLY YAMAHA'S 1959 -63 YDS's
YDS3 is a 1964
Replied by MarkT on topic EARLY YAMAHA'S 1959 -63 YDS's
28 Aug 2020 17:56
#295
- swm
avc2020,
YDS3 only takes 4 frictions, I had two YDS3 engines rebuilt so only 4 friction plates were installed (if I understood question correctly). Engines were built by my local shop so I can't comment "how to", but they didn't mention any challenges installing the new Barnett discs. There are some twin cylinder experts here but you should also join this group (see link) which focuses solely on early Yamaha twins.
yamahaydsownersgroup.groups.io/g/main
YDS3's are great bikes.
Good luck!!
Good luck!!
28 Aug 2020 18:28
#296
- avc2020
Thank you for the replies!
28 Aug 2020 19:27
#297
- avc2020
Hello everyone,
I ended up buying another steel and using 4 of the Barnett frictions and the clutch is working great. If anyone has any other questions let me know I will try and help.
Thanks again for all the support!!
22 Sep 2020 08:57
#298
- Tunaphartt
Replied by Tunaphartt on topic EARLY YAMAHA'S 1959 -63 YDS's
Hellos guys i new to this forum and need help identifying my grandfathers Yamaha. Any and all help is welcome thanks !!
12 Jul 2021 13:56
#299
- Swoop56
Replied by Swoop56 on topic EARLY YAMAHA'S 1959 -63 YDS's
That looks like a YDS3 250 , probably about 64 vintage . The early ones had the round badge on the fuel tank .
12 Jul 2021 14:27
#300
