Oil pump is floating the crank case, DT 250B
- GaryDean
Replied by GaryDean on topic Oil pump is floating the crank case, DT 250B
Ive had another look today and the sealing area is rubber, are these inserts available to buy
25 Oct 2022 10:10
#11
Replied by MarkT on topic Oil pump is floating the crank case, DT 250B
Yamaha used an external check valve on some models and some have used them. I haven't.
Part number 8CH-1316A-00-00
25 Oct 2022 11:39
#12
- GaryDean
Thanks mark, does this fit in line on the carb feed pipe
25 Oct 2022 23:10
#13
- GaryDean
I seen a repair kit on yam bits that had the actual seat with it, listed for an SR500, so wondering if they used the same part for all pumps, no dimensions though
26 Oct 2022 09:46
#14
- GaryDean
part number for the seat 583-13113-00-00 xt500 sr500 etc not sure though if the same as the dt
26 Oct 2022 09:56
#15
Yes I believe the 8CH check valve goes on outlet side of pump.
26 Oct 2022 19:43
#16
