1981 DT125 H
  • bsadan
  • bsadan's Avatar Topic Author
1981 DT125 H was created by bsadan
Glad I found this site. I just got a 1981 DT125H with a stock piston P/N 2A6-11631-00-96. My bike has 90PSI compression and I am looking for the next oversize piston but so far, I have had no luck finding one. I have several bikes and have been riding since 1965.
Thanks Dan
09 Dec 2024 11:30 #1
Replied by Gr8uncleal on topic 1981 DT125 H
 from near Salisbury, UK.
I wonder if the 2A6 parts superseded to 2N4? If so, CMSNL have oversize kits.
Search results for 2n4-116 - page 1
09 Dec 2024 11:48 #2
Replied by MarkT on topic 1981 DT125 H
I'd say you're correct Alan...  US online parts books are bad for that model.
Piston should not be too hard to find.
09 Dec 2024 13:22 #3
  • bsadan
Replied by bsadan on topic 1981 DT125 H
Thanks I will try and find out.
09 Dec 2024 14:31 #4
Replied by RT325 on topic 1981 DT125 H
Welcome from NZ.
Tell me more about te BSA part of your name if i'm taking the correct inference from it..
I had BSA's back in the "60's.
Also worked in the local Yamaha shop through most of my working life. Cheers.
ps, apart from feeling compression by hand on the kickstart--does it feel positive or falls through with little resistance--how does it idle. Is a good idle like not going to fade off--or does it struggle to hold a possitive idle.
Set of rings is always a good idea then you know what's in there.
"81 125 Might've still had points ignition although nothing to do with compression.
Last edit: 09 Dec 2024 15:14 by RT325.
09 Dec 2024 14:56 #5
Welcome!  Bsadan
If the bike was running good and not rattling it might be fine...  compression gauges are not a great way to "diagnose" the smaller engines unless you have experience with that exact gauge on that engine....  many automotive gauges read way low on a 125 or smaller engine.
The following user(s) Liked this Post: Reed valve Richards
09 Dec 2024 15:06 #6
Replied by Ht1kid on topic 1981 DT125 H
Greetings from Tennessee
09 Dec 2024 15:53 #7
  • Reed valve Richards
  • Platinum Member
  • Platinum Member
Replied by Reed valve Richards on topic 1981 DT125 H
BSADan look forward to seeing some pix as I have the '78 E model
Yo Joe, Go Joe
09 Dec 2024 21:28 #8
Replied by Tinkicker on topic 1981 DT125 H
80 on model pistons were 3J1 not 2A6/ 2N4.  Dunno what the difference is though.  I have it in mind that the crown shape is different, but cannot remember why I think that.
I know that when looking for a new oem piston, 3j1 was common and I avoided them like the plague.
Edit.  Barrel part number is same on both.  Head part number is different.  Betting changes to combustion chamber shape.
81 has 1bhp more power than 79 and 2ft lb more torque.
Last edit: 09 Dec 2024 23:44 by Tinkicker.
09 Dec 2024 23:29 #9
Doh. 2A6 is 125. I have 175 engraved on my brain. What can i say.... I am a sorry assed fool...
I see 125 and it automatically turns into 175 in my brain. It took a pic of the tabasco fiasco cylinder head to think.... Hang on a minute.... 2A6 on a 125?  Yup.  My bad.
Walks away with head hanging in shame.....
Last edit: 13 Dec 2024 16:46 by Tinkicker.
13 Dec 2024 16:43 #10
