74 DT360 project.... broke the pulser already
- shopgrant
74 DT360 project.... broke the pulser already was created by shopgrant
imgur.com/78JAuR2
I got this bike a few years ago and got it running right when right when I got it. It shot tons of oil out of the exhaust so I figured the crank seals were bad.
Then let it sit and worked on other projects. Finally got back to it over the weekend. actually looked really clean inside and the crank seals seemed flexible
imgur.com/vL0mfZc
Didn't know that I need to inspect the mag cover FIRST. Broke my pulser, so now my first order of business is figuring out an ignition.
imgur.com/COS02vE
imgur.com/HkXtSVZ
after searching the forum all day yesterday, it looks like I have 3 options.
1. find another pulser (risky)
2. 74-78 DT 250 stator and flywheel conversion for points (best option)
3. new magneto assembly from vape or rex. ($$$)
I want to do the points conversion because that seems the most reliable but doesn't seem like there are any for sale now. So is there any other bikes that have the same pulser part#? DT400s look like the stators are extremely similar to the dt360 stator plate I have.
imgur.com/vL0mfZc
imgur.com/COS02vE
imgur.com/HkXtSVZ
02 Apr 2024 18:27
- Schu
Replied by Schu on topic 74 DT360 project.... broke the pulser already
I didn't know the 250 parts option was good thru 78. I thought it was only 74 and 76.
Replied by RT325 on topic 74 DT360 project.... broke the pulser already
Pretty sure the "79 dt250 went to the good cdi stator & pulser like the 400 but would need the box too--& flywheel of course.
Sorry i see you're DT360A "but same applies all should fit "79 250 & "77 400 onwards.
Replied by MarkT on topic 74 DT360 project.... broke the pulser already
I'm fairly certain the 74 DT360 and 75-76 DT400 had the same pulser coil.
US 77-78 DT250 points systems can also work as a replacement... but might take a little more work to accomplish correctly.
If I remember correctly, the 77 on bikes were wired differently and lost the "day/night" battery charge selection in the headlight switch... Yamaha wired the voltage regulator into the battery charge system so some creative thinking and/or additional parts and wiring might be required when installing 77-78 points on an earlier model. Not impossible, but not as "plug and play" as using a 74-76 points magneto.
Also, if buying a system, always best to get a "matched set".
Last note is that the challenge with the earlier (pre-74) points magnetos is that the flywheel was bigger. The new engine design that came out in 1974 has a smaller opening for the ignition system and the earlier flywheel will rub the case if it fits at all. Some have reportedly done some machining to get the earlier magneto system to fit in the later case. I'm not sure this is wise or how difficult it is... but it might be an option.
The following user(s) Liked this Post: swm, Schu, Ht1kid
03 Apr 2024 07:31
- shopgrant
Replied by shopgrant on topic 74 DT360 project.... broke the pulser already
Awesome good to know! The early magneto sounds pretty tempting... I'm a machinist so it would be fun to figure it out and I have a line on an early set. From my reading I too saw that the early kit would work with modification but assumed it was the tapers were different which didn't seem cost effective to recut the taper and the tapered slot. However If its just the size of the fly wheel then I think ill give it a go!
03 Apr 2024 16:04
- Schu
Just curious. Would you machine the flywheel or would you modify the side case? I would assume the flywheel would go out of balance if you did any machining on it.
03 Apr 2024 16:23
On my useless phone so hope it posts. Tapers will be the same all the way through the years on those from “68 to “79 or so. But advantage of the later cdi is you have electronic retard for starting. Early one did too although different pulses & how it did ‘that’—performed that duty. Be sure the decomp is clear if carbon in the cylinder drilling & also the drilling going down to the exhaust outlet from the valve. Has to be cleaned from bottom to top where valve sits as can’t get at it from the top above the valve as will be blanked off in the top fin.
03 Apr 2024 16:28
- shopgrant
I'm not sure what Ill machine yet. I just placed an ebay order so once it comes and its in my hands ill have a better idea. But right now I'm thinking the same as you. Seems like I'm less likely to encounter problems if I clearance the case.
RT thanks for the tips ill start there while im waiting for parts to come in.
- DEET
- Moderator
Replied by DEET on topic 74 DT360 project.... broke the pulser already
I have a couple of NOS pulsars available. Both have the correct resistance to prove they are good.
Since there are not to be found anywhere for sale, they are not cheap.
Just an option for you should you decide to go back stock.
The following user(s) Liked this Post: swm, RT325, Swoop56, Ht1kid
04 Apr 2024 10:21
- shopgrant
Had some delays but I'm back working on the bike with some success.
The early points kit I got, works but the points cam was extremely pitted, so I bought another flywheel off ebay. The separate fly wheel I bought didn't end up working with the magneto. As stated earlier it the thread "make sure they're a matched set" learned my lesson. Now with the original flywheel that is heavily pitted I'm getting spark. Not ideal for reliability but its working so cant complain too much.
I do want to know why the magnetos don't work as non matched pairs though, the flywheels just have magnets in them so I would have thought you can switch them out? If there's a way to get them to "talk to each other" I'm all ears because I would love to run the less pitted/better condition flywheel.
Anyways here was the process for machining the earlier flywheel to fit the 1974 DT360 case:
imgur.com/hevunat
Pressure turning fixture
imgur.com/A4ffsAE
Flywheel in the fixture
imgur.com/xjjX3vR
Left to right: Unmachined early flywheel, Machined early flywheel, stock cdi flywheel
imgur.com/uhsLxOg
Stock cdi flywheel compared to machined early flywheel
imgur.com/3e6aL30
Machined flywheel in case
imgur.com/Gkwn3hq
Dimensions for the machined flywheel in Inches.
So to make it fit, all you need to do is machine the OD of the flywheel for clearance. pretty simple. However i haven't figure out the wiring yet, just hooked the points up to the coil. Also has anyone replaced a condenser on one of the earlier bikes? there's 4 wires soldered to the top. Want to replace mine for peace of mind.
Here is the magneto:
imgur.com/ICDuRri
imgur.com/hevunat
imgur.com/A4ffsAE
imgur.com/xjjX3vR
imgur.com/uhsLxOg
imgur.com/3e6aL30
imgur.com/Gkwn3hq
imgur.com/ICDuRri
