New here... Project 1975 Yamaha DT400 Enduro
  • d-meng
  • d-meng's Avatar Topic Author
Hey guys, new to this forum and these older Yamaha's. Just started to tear down my new to me 1975 DT-400 Enduro. Search feature on here isn't the easiest to navigate and was about 11 pages deep before I decided to make this post. Can anyone guide me to the service manual for this unit. Thanks in advance and wish me luck!
The following user(s) Liked this Post: mdscott, Bent Trigger
Last edit: 25 Aug 2022 03:59 by d-meng. Reason: Added pics
23 Aug 2022 16:31 #1
Replied by AirborneSilva on topic New here... Project 1975 Yamaha DT400 Enduro
Here's a link for you but in the future look up top of the page and click on "tech library", there's a ton of information there...
75 DT400 service manual
The following user(s) Liked this Post: Bent Trigger
23 Aug 2022 16:37 #2
Replied by Gr8uncleal on topic New here... Project 1975 Yamaha DT400 Enduro
 from Salisbury, UK.
For searching, use the "Search" or "Search Forum" button on the second row of tabs, not the "Search" on the top row.
The following user(s) Liked this Post: d-meng
Last edit: 23 Aug 2022 22:59 by Gr8uncleal.
23 Aug 2022 22:58 #3
  • d-meng
Awesome, thanks for help with the search. Much appreciated. I am from New Jersey, but not the armpit section, lol. Bummer pics can't be uploaded right now, I'd like to document my progress. So far engine is out, cylinder is off and I will clearly need a rebore, piston, etc.
Last edit: 24 Aug 2022 06:18 by d-meng.
24 Aug 2022 06:16 #4
That is an old message, pics can now be uploaded, but see my link below regarding how (give me a few mins to do this).
Edit - can't find the thread I was looking for!
So, use "Attachments" button below to add photos (max 5 per post, I think). Once you've done this, make sure that the cursor is where you want the photos to appear (usually after the last piece of text). Then insert each photo individually - ie don't use the "insert all" button (this will duplicate everything). Finally, press "Submit".
Last edit: 24 Aug 2022 07:57 by Gr8uncleal.
24 Aug 2022 07:48 #5
  • d-meng
Update.. I picked up some more parts for the enduro as well as an extra frame with engine from a member here on eBay. Petcock and new clutch cable from cmsnl.com.
Last edit: 08 Sep 2022 03:53 by d-meng.
08 Sep 2022 03:49 #6
do not kick it over until you remove the flywheel and clean all the debris from the stator and flywheel.  You will damage the pulser and thats a whole new problem.
Doug
08 Sep 2022 11:00 #7
Welcome from NZ. Damage doesn't look pretty. Wonder what's been going on, no oil or been thrashed to the point of melting. Bummer. I guess the bottom end aint good either. Time to go "in". Any questions just ask.
08 Sep 2022 16:31 #8
  • none_of_my_bikes_run
  • none_of_my_bikes_run's Avatar
Replied by none_of_my_bikes_run on topic New here... Project 1975 Yamaha DT400 Enduro
Welcome - from another DT400 owner in NJ (well, philly/south jersey). This site has helped immensely during my rebuild.
One trick I've used to find old relevant forum posts is to use google. For instance, id search "dt400 progressive site:https://www.yamaha-enduros.com/" and found MAKOTOSUN's shock installation & review thread within the first couple results. Which is exactly what I was looking for. Whereas that post is somewhat buried when looking in the site's Search feature. Not saying one is better than the other, but when I have a question, I try both methods!
Good luck with the bike!
The following user(s) Liked this Post: MarkT, Schu, Ht1kid, d-meng
Last edit: 09 Sep 2022 06:44 by none_of_my_bikes_run.
09 Sep 2022 06:42 #9
Replied by DT-Steve985 on topic New here... Project 1975 Yamaha DT400 Enduro
Welcome from the UK, good luck with the rebuild, is this the first one you’ve done?
09 Sep 2022 07:56 #10
