Removing oil tank and air cleaner form a '74 360DT - any Tricks in Removal?
- warmblood58
Removing oil tank and air cleaner form a '74 360DT - any Tricks in Removal? was created by warmblood58
Started to pull air cleaner box and oil injection tank but . . . . no go, all 10mm's removed as is air intake snorkle off airbox. Any tricks? Anything else I need to pull to make this work? Help! Thanks! Pardon typo in Subject, typing too fast
- msavitt
Replied by msavitt on topic Removing oil tank and air cleaner form a '74 360DT - any Tricks in Removal?
hmm...I remember it being a tight fit and worrying about scratching nice green paint but didn't have an issue removing. I do think that I had the tool tray, silencer and exhaust pipe off...maybe because I couldn't get it out?
17 Feb 2021 17:03
- warmblood58
Replied by warmblood58 on topic Removing oil tank and air cleaner form a '74 360DT - any Tricks in Removal?
17 Feb 2021 17:28
- warmblood58
Some wiring harness shifted might work - would love to not remove exhaust at this time
17 Feb 2021 17:30
- treeves
Replied by treeves on topic Removing oil tank and air cleaner form a '74 360DT - any Tricks in Removal?
Did you take the cap off the oil tank?
17 Feb 2021 19:20
- msavitt
Yes!
17 Feb 2021 19:33
- warmblood58
17 Feb 2021 20:02
Replied by MarkT on topic Removing oil tank and air cleaner form a '74 360DT - any Tricks in Removal?
Ichiban Moto has the solution. Skip to about 1:45
17 Feb 2021 20:56
- Makotosun
- Administrator
Replied by Makotosun on topic Removing oil tank and air cleaner form a '74 360DT - any Tricks in Removal?
same frame setup as a DT400. You will need to remove the exhaust if I recall. It's sort of a puzzle how it goes together, and there is a definite order of things.
The following user(s) Liked this Post: nhsteve, warmblood58
17 Feb 2021 21:05
- warmblood58
18 Feb 2021 07:03
