Any tips for removing stator side crank seal?
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Any tips for removing stator side crank seal? was created by AirborneSilva
Hey guys, I tried removing the crank seal on the stator side, did the clutch side yesterday, and figured out I wasn't going to use a screwdriver like I did on the other side so I went to a buddy's auto shop and borrowed a seal puller but when I got home I found out there's no lip for the tool to catch on.  It's a 76 DT400.  Thanks for any helpful hint's, tips and or secrets!  Tony
03 Feb 2021 16:06 #1
Replied by HouseofEnduro on topic Any tips for removing stator side crank seal?
I put a drywall screw into the rubber part of the seal, next to the metal edge, then use pliers to pull it out. Simple job.
03 Feb 2021 17:54 #2
Replied by yamahahaha on topic Any tips for removing stator side crank seal?
03 Feb 2021 18:00 #3
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic Any tips for removing stator side crank seal?
Thanks, I'll give that a try but wasn't aware there was a rubber edge except the one closest to the crank.  I did try drilling a small hole in the metal part, using a deck screw but just pulled the screw out...
03 Feb 2021 18:00 #4
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thank you Yamahahaha that seal looks different than mine, looks all rubber, mine is metal except closest to the crank.  I did try a screw but only pulled the screw out and didn't budge the seal...
03 Feb 2021 18:03 #5
Maybe send forum member run103  a PM... he has worked on quite a few DT400's
03 Feb 2021 18:14 #6
Drywall screw worked for me.
03 Feb 2021 18:16 #7
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thanks, I may have to give him a shout!
03 Feb 2021 18:20 #8
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Message sent, hopefully he has an idea for me.  Thanks again!
03 Feb 2021 18:26 #9
Replied by Jammyyammy on topic Any tips for removing stator side crank seal?
I used a punch to make a small hole in the metal of the seal (don't be too heavy handed). I've seen some YouTube clips where they drill a small hole, but then you get the problem/worry of swarf.
05 Feb 2021 09:11 #10
