What after market shocks for 1974 Dt 360a
- treeves
What after market shocks for 1974 Dt 360a was created by treeves
I have had the frame, swing arm and other parts powder coated. The gas tank , oil tank and all the silver parts are at the painter. I have started putting some parts back on bike. I would like to find some after market shocks or if anybody is rebuilding the original (mine rusty). Thanks for any advice
24 May 2020 18:57
Replied by Gr8uncleal on topic What after market shocks for 1974 Dt 360a
I've seen mention of Redwings for some models and the originals can be rebuilt - have a search of the forum for the relevant threads.
I'd steer away from those with the piggyback gas canister (ie at the top), as they can foul around the exhaust area.
25 May 2020 00:34
- Schu
Replied by Schu on topic What after market shocks for 1974 Dt 360a
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=360913720923&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- mdscott
Replied by mdscott on topic What after market shocks for 1974 Dt 360a
- Schu
No, I never rode my 400 with the original shocks. They were solid rust. But my 360 still has a good set of the original thermals and I can't really say I noticed one being better than the other. But all I do is ride around the two mile trail on my property, or blast down the gravel roads. I haven't negotiated a series of whoops or got air in over 20 years. I still remember the last time I went down trying to keep up with my boys while riding an XR600. I hit the ground before I knew what happened. Knocked the wind out of me. I couldn't even pickup a gallon of milk for at last a week. Probably cracked a rib and never did anything about it.
Dang, there I go telling a story again. Sorry folks.
25 May 2020 11:46
- DaveHunter
Replied by DaveHunter on topic What after market shocks for 1974 Dt 360a
As RT would say... I published an essay then pushed wrong button and erased it....
Before writing all that again what is your rear shock budget & expectations ? Hagons on my DT360
- treeves
Replied by treeves on topic What after market shocks for 1974 Dt 360a
I am thinking 200 to 300 hundred. I would be happy with any of the shocks mentioned but I have not found anything that says it will fit my bike. I will be riding the bike on the street and very little dirt.
25 May 2020 12:25
- Schu
They may not list your DT360, but that doesn't mean they won't fit. That seller with the ASSAULT shocks has several listed on his eBay store. The eye to eye measurements range from 13, 13.25, and 13.5. The 13 inch would probably fit fine being a smidge taller.
25 May 2020 12:35
- treeves
I did measure my shocks and they measure 12 inches. Will the 13 inch be to long?
26 May 2020 07:22
- KennyV
Replied by KennyV on topic What after market shocks for 1974 Dt 360a
The shocks that are in the picture and on Schus 400 on post #3 would be a good choice because you will have plenty of clearance between the shock and chain / sprocket. My red wings on my RT have the spring tension adjuster much lower and there's very little clearance between the chain / sprocket and adjuster.
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
21 CRF300l Rally
26 May 2020 08:02
- Home
- Forums
- Community
- Tech Library
- Market
- User Menu
