DT360A wiring diagram question
- WillyH
DT360A wiring diagram question was created by WillyH
There is a table on my wiring diagram that shows 3 positions on the left axis: Off, I, and II. My ignition switch only has two positions, Off and on. What is position II referring to?
Replied by MarkT on topic DT360A wiring diagram question
That's one of the (unfortunately many) boo-boos in Yamaha literature. Before 1974, the lights were controlled by the main key switch (position II). Somehow the legend for the earlier switch made it onto the 1974 diagram.
The Service Manual in the Tech Library has the correct legends in the Electrical section itself.. (not on the diagram!)
The following user(s) Liked this Post: Snglsmkr, Gr8uncleal, Jack
01 Mar 2020 20:37
- WillyH
Replied by WillyH on topic DT360A wiring diagram question
Brilliant! Thank you!
01 Mar 2020 20:48
- WillyH
A couple more questions have come up. I seem to have a Grey wire in the headlight cup, but I don't see Grey anywhere on the diagram.
Also your table mentions Y/W as a wire color, which is nowhere on the diagram either. Are these more mistakes?
02 Mar 2020 19:17
Not "my" table... it's Yamaha's.
Yamaha is not too precise... the "Y/W" is the AC headlight circuit power wire from the stator which is traditionally solid yellow in Yama-wiring... could be solid yellow out of the stator and changes to Yellow/white at the switch harness. (Similar thing happens on many models with points ignition and the black or black/white. )
Not sure about the grey. They do list grey in one of the Service Manual wiring color legends but I don't see it on any of the diagrams. Is it a European model? They had slightly different wiring. Pictures of what you're looking at might help. Can you trace where it goes?
03 Mar 2020 06:43
- WillyH
Good idea to trace it, which I find leads from the headlight shell up to the Tachometer indicator lights. It goes into the same receptacle as the Db wire, so according to the wiring diagram it must be Dg. Sure doesn’t look like it to the naked eye, but with the camera flash at the instrument end on I can see some green. In any case, I’ll call it Dg. So that mystery is solved but here is another one:
The wiring diagram says that the wires to these instrument indicator lights are Dg, Db, B, and Y. Y shows as going to three indicator lamps. However, on my bike I find that I only have one Y wire, and two L wires.
- Db and Dg go to the flasher indicator
- Y and B go to the high beam indicator
- L and B go to the Tachometer meter light
- Also, L and B go to the speedometer meter light (not pictured).
- DEET
- Moderator
Replied by DEET on topic DT360A wiring diagram question
High beam indicator?
03 Mar 2020 09:42
Yes, traditionally the Yamaha instrument light illumination wires are blue. (They are powered by yellow when light switch is "on")
If your diagram shows yellow wire from switch to bulb, it's wrong.
03 Mar 2020 12:20
- WillyH
That would be from page 204 of the service manual in the tech library.
74 DT250-DT360 service manual
04 Mar 2020 17:32
There are also several diagrams in the body of the Service Manual...
Page 132 Figure 7-4 is far more accurate (and in my opinion, easier to read). It shows a blue (L) in the main harness connecting to blue/red (L/R) at the instrument illumination bulb harnesses.
04 Mar 2020 17:49
