74 DT360 - Cylinder Plate Washer Help
- EnduroTEX
74 DT360 - Cylinder Plate Washer Help was created by EnduroTEX
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=202815005610&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- DEET
- Moderator
Replied by DEET on topic 74 DT360 - Cylinder Plate Washer Help
I think that I have a set.
03 Feb 2020 08:12
- EnduroTEX
Replied by EnduroTEX on topic 74 DT360 - Cylinder Plate Washer Help
DEET this would make my morning Thank you.
Your help is all over this build with Frame sticker/ Speedo/Tach refurb and the oil pump it is only fitting that you leave your signature on the motor as well Haha. I may have to have a DEET sticker made to proudly display on the fender
03 Feb 2020 08:30
- DEET
- Moderator
I have 4
03 Feb 2020 08:46
- DEET
- Moderator
03 Feb 2020 08:48
- TerryM
Replied by TerryM on topic 74 DT360 - Cylinder Plate Washer Help
Check the bottom of the stud holes in the cylinder. They may still be stuck down in the bottom. I remember someone asking about these a few years ago and they ended up finding them stuck down in the holes. They had bit into the material of the cylinder just enough that they didn't want to come out.
The following user(s) Liked this Post: Enduronut, MarkT, nhsteve, EnduroTEX
03 Feb 2020 08:49
- Grussell
Replied by Grussell on topic 74 DT360 - Cylinder Plate Washer Help
Rocky Mountain ATV/MC shows they have them with a 5-7 day ship time. I have ordered from them for my 78 DT400 I am rebuilding.
1978 DT400
1975 DT250
1976 YZ125X - my post vintage race bike
2022 KTM 300XCW - my race bike
1975 DT250
03 Feb 2020 09:42
- Enduronut
- Founder Moderator
Replied by Enduronut on topic 74 DT360 - Cylinder Plate Washer Help
I'll also add to Terry's comment, that this was by design. . . . .
Yamaha intended for them to embed themselves and not come out,
So take a second look just to be sure!
Replied by MarkT on topic 74 DT360 - Cylinder Plate Washer Help
Yes as Terry and EN said, they commonly almost become part of the cylinder.
(Nice to know that was by design, thanks EN)
Sometimes one or two can fall out during cleaning/handling/machining so good to always check all are there. If missing, nut runs out of threads before cylinder is clamped tight... so nut might act like it tightened up but won't be doing anything.
03 Feb 2020 13:49
Replied by RT325 on topic 74 DT360 - Cylinder Plate Washer Help
should be still trapped down there. maybe a new cylinder comes without them.
03 Feb 2020 18:45
