pressure testing 125 two stroke
  • coxey2
  • coxey2's Avatar Topic Author
Replied by coxey2 on topic pressure testing 125 two stroke
wish it had obvious causes like yours. going to be putting in new seal thanks
18 Dec 2019 04:49 #11
Replied by RT325 on topic pressure testing 125 two stroke
just looking at an MR175 as near as CR125 i can find on partzilla & RH seal is inboard of the main bearing which is a total dismantle to change so i'd be thinking hard before doing--like is it really 'that' problem. Left side looks normal to change in the drawing so hopefully 'is' & not trapped from the inside like my KX125. Video is good.
18 Dec 2019 12:17 #12
Last edit: 18 Dec 2019 14:29 by RT360Fan.
18 Dec 2019 14:28 #13
  • coxey2
about 6 hours and very carefully replacing right and left seals and new gaskets of course. Exact same bogg. won't even pull itself. idles fine. harder to start now. it runs perfect for about 10 seconds or three revs and then the bogg or loading up starts. Its got me stumped....
26 Dec 2019 19:21 #14
Replied by MarkT on topic pressure testing 125 two stroke
I'd try a brand new spark plug.
Bad CDI would be my next guess... and it's just a guess.
26 Dec 2019 19:30 #15
video please with good audio & please make video as long as feasible timewise to get a good listen.
26 Dec 2019 20:40 #16
Replied by darinm on topic pressure testing 125 two stroke
new spark plug wires too. All electronics have an infant mortality rate, anything you replaced since it was last running well would be highly suspect in my book, I've seen condensers and similar components fail in ~1h of initial use.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
26 Dec 2019 21:01 #17
  • coxey2
its gonna be a bit, I stripped one of the cylinder studs taking it apart so many times....
26 Dec 2019 21:23 #18
  • coxey2
I have an extra coil and cdi. will give it a try. Ive been thru 4 new plugs, all still white and good.
26 Dec 2019 21:24 #19
Replied by Snglsmkr on topic pressure testing 125 two stroke
The symptoms line up with fuel starvation due to the float bowl not refilling quickly enough.
Thin flakey crud in fuel tanks of older bikes can cause major restrictions in the fuel delivery from the tank to the carb.
The float bowl can fill while not running, but once started the fuel demand can exceeded the refill rate of the float bowl. There may be enough fuel delivered for idling conditions but larger throttle openings may exceed what the restricted delivery rate of fuel can support.
Also, verifying that the second carb was a known good one would help eliminate carburation as a strong possibility.
27 Dec 2019 11:37 #20
