DT400 Porting
  • Blazer
  • Blazer's Avatar Topic Author
DT400 Porting was created by Blazer
Hey there, can anyone recommend someone to port my 78 DT400?
Id like to get more power out of it. Maybe something close to a IT400.
Im in CA if that matters.
04 Mar 2026 21:51 #1
Replied by RT325 on topic DT400 Porting
I've done maybe stupid things "which I'm real good at with years of mistakes" whte I've made a 5mm alloy base plate to lift the cylinder then taken 5mm off the top of the cylinder in my primitive old lathe. Then spun the head & machined the step off to reclaim compression or hopefully raise it more than original to make up for raised ports. Realy need a better exhaust than standard. Na, just go get an IT400 motor. I got one from the wreckers about 30 years sgo which I fitted in my monoshock DT250 frame. THAT lit it up haha. Had a yz exhaust on too. Memories.
05 Mar 2026 14:59 #2
